Headers Vs. Stall
Old Aug 24, 2006 | 06:41 PM
Frosty's Avatar
A converter will net you better times at the track over headers.(if racing is your thing)
Old Aug 24, 2006 | 06:50 PM
radz282003's Avatar
Stall that beech first. You will gain more with a stall, with traction, than you will get with LTs. Yeah, there' s no denying the sounds will be A LOT better with LTs, but, if you want gain, your stall is a better bet.
Just remember, go big or go home.
Old Aug 24, 2006 | 08:42 PM
Not4Racin's Avatar
My plan:
1.Nitrous....100 dry shot...100 hp = 1 sec quicker
2.Stall...3800 plus cooler and tune = 1/2 sec quicker
3.headers....pacesetters uncoated with y pipe.= 3/10 tenths quicker
Maximum go for least dough at each writing of the check.
Old Aug 24, 2006 | 11:16 PM
Cop Car's Avatar
Originally Posted by cha1nz1535
im definitley leaning more towards a stall now...keep the input coming guys
dont think you are just going to spend $600 then, start thinking more around $1200 for everything
Old Aug 24, 2006 | 11:17 PM
cha1nz1535's Avatar
yeah im still kind of undecided because of how much it will cost to get a tc up a running...
Old Aug 24, 2006 | 11:57 PM
cws T/A's Avatar
Default whats the world coming to
Originally Posted by rgk615214
what exactly is a stall?? I'ver heard about them on several threads and done searches but what exactly is it and what does it do???
As far as your question, if a stall is just a mod to up horses, i'd definitely go with headers because the sound of the car is a world of difference.
A ''stall'' is a high performance torque converter for automatic transmissions
search HADAA! danielson
Old Aug 25, 2006 | 12:01 AM
cws T/A's Avatar
Originally Posted by Cop Car
you need more than $600 for either one.
if you get a stall you need to have it installed and for best results should have it tuned
if you get LTs you will have to install them, then get at least a y pipe (my brothers car had pacesetters, a y pipe and then stock catback on it and it sounded nice) if not getting a whole cat back or true dual set up, then you need to tune out your front O2 sensors and maybe even your EGR
my suggestion would be coated pacesetters, TSP y pipe and stock catback, get a tune to fix your O2s and enjoy your slightly faster better sounding car.
If you tune out the front o2's your car will not run at all
I think you meant the rears
Old Aug 25, 2006 | 12:39 AM
DOUBT IT's Avatar
Stall. Period.
It dropped 6 tenths off my ET. Headers can't do that.
 Michael S. Palmer
Old Aug 25, 2006 | 02:16 AM
Z2K_MrJ's Avatar
Board Certified Idiot
You Will Need More then $600 for a Nice Set of Good Headers.. Also you Highly Recommend $500 Tune..
As for the TC you will See More of a Notice off The Line & From a ROLL No Dout. Also the Coast of Tuning you will Need. Will Coast About $300 LESS
My VOTE is go With the STALL baby!!
Old Aug 25, 2006 | 11:34 AM
bigfoot2thefloor's Avatar
3600 vig. no doubt best thing you can do to your car but definatly headers after that.... be prepared to burn rubber!-Invest in a tran cooler also cars no good without a transmission..
Old Aug 25, 2006 | 12:00 PM
cha1nz1535's Avatar
In the end which will cost less...for the tune i was going to buy the basic gm tune from speed inc for $150 and that will work for both the headers and the stall
Old Aug 25, 2006 | 12:13 PM
  #32
2001CamaroGuy's Avatar
I agree
The TC will cost you to have it installed, where as the headers and y-pipe can be done in the driveway with friends.
Old Aug 25, 2006 | 12:33 PM
  #33
losiguy's Avatar
Originally Posted by Not4Racin
My plan:
A 100 Dry shot will not make you go 1 full second quicker. With a NX 150 wet I went from 12.8 to 11.9. I dont see a 100 dry doing that.
Chad
Old Aug 25, 2006 | 01:13 PM
  #34
Roarin_8's Avatar
Maybe he meant 100 dry shot to the wheels which would equal about 150 shot at the flywheel.
Old Aug 25, 2006 | 01:33 PM
  #35
john5632's Avatar
I did hedders first then stall,but if I had to start all over I would have done the stall(TCI34-3800stall) first made a HUGE diff.make sure you get a trans.cooler though.
Old Aug 25, 2006 | 01:36 PM
  #36
Cop Car's Avatar
my car has no MAF, no O2s and no polution control devices at all
Old Aug 25, 2006 | 01:48 PM
  #37
01FormulaTA's Avatar
I got headers, ory, and LM2 and Im def wishing I woulda just went with a stall first.....
Old Aug 25, 2006 | 01:49 PM
  #38
why in the world would you remove the MAF or O2s unless you HAVE to?
Old Aug 25, 2006 | 02:08 PM
  #39
01_ram-air's Avatar
Stall first PERIOD. Trust me, that's the way you want to go. Don't get anything under 3600. I have a 4000 stall, daily driven. And you don't NEED drag radials with a stall. You don't want headers without the rest of the exhaust system so keep that in mind. Headers will not give you anywhere near the difference as a good stall will. Did I mention that you want to get a stall first?
Old Aug 25, 2006 | 02:11 PM
  #40
cha1nz1535's Avatar
Im on a budget...so whats the best stall?
