90mm MAF
Old Aug 25, 2006 | 09:47 PM
SlickVert's Avatar
Default 90mm MAF
Does any make a true 90mm MAF or larger that will work with an LS1?
I am running an 85mm Z06 MAF now, but it is more restrictive then my 90TB, looking for something bigger.
Bob
Old Aug 25, 2006 | 09:55 PM
Patrick G's Avatar
LS1 Tech Administrator
Do you really need the MAF? Speed Density closed loop tuning would solve your problem while still allowing broad correction for altitude and weather changes. The only reason why I'd see running a MAF would be for a dry nitrous shot, but now with EFI Live's custom nitrous operating system, you can ramp up the injector pulse width without even needing a MAF...very cool.
To answer your question, yes, there are several aftermarket manufacturers that make oversized MAFs for the Ford market. I'm not sure how involved it would be to adapt to the GM wiring and software.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 25, 2006 | 10:00 PM
00transamnh's Avatar
would there be any advantage to making a car with my mods a speed density tuned set up? sorry, dont mean to jack thread
Old Aug 25, 2006 | 10:13 PM
BOWTIE's Avatar
OBD2 testing... Unless someone has figured out a way to get around that in the last year or two.
Old Aug 25, 2006 | 10:46 PM
Beast96Z's Avatar
Pro-M makes a true 90mm MAF for the F-body. Just pricey, so you never here about it.
Old Aug 26, 2006 | 06:31 AM
SlickVert's Avatar
Thanks, I will look into it.
Old Aug 26, 2006 | 06:40 AM
SlickVert's Avatar
Patrick
I am planning to do a SD to get VE table correct, then reconnect and correct the MAF table. I thought that having the MAF connected, it would help keep the tune closer with different weather condition changes. Is this true?
I am not sure as I am new to the SD tuning stuff.
If the tune could stay calibrated year round I would go MAF-Less
Bob
Old Aug 26, 2006 | 08:07 AM
TAQuickness's Avatar
I've had 2 inspections (OBD2) with no issue.
Old Aug 26, 2006 | 08:39 AM
redtail2426's Avatar
the only time i will go speed density is when i have a FAST lsx 90mm intake with the 90mm throttle body,the mass air will just hinder its performance,but with the ls6 and ported throttle body,its staying mass air.Just be sure your speed density tunes are dead on and your good to go.
Old Aug 26, 2006 | 08:56 AM
Patrick G's Avatar
Originally Posted by SlickVert
Patrick
Bob
Bob, every new vehicle made by Chrysler comes speed density...no MAF! As long as your VE tables are spot-on, SD tuning is every bit as accurate as running a MAF.
__________________
Old Aug 26, 2006 | 09:02 AM
SlickVert's Avatar
Thanks Patrick,
I will give it a try.
I am still using Edit and ready to upgrade to a new tuning tool.
What do you recommend?
Bob
Old Aug 26, 2006 | 09:04 AM
Rothman's Avatar
I've read several posts stating that running a Sd tune with a smaller cam is not very effective. Please correct me if I'm wrong. Just going by info that I found doin searches here. I'm goin with a fast 90/90 and a custom Lsa 228R with LS6 PRC's and was wondering about the whole 90 maf thing too.
Old Aug 26, 2006 | 09:09 AM
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
Lingenfelter makes a very reasonably priced 100mm MAF.
Old Aug 26, 2006 | 09:44 AM
SlickVert's Avatar
Thanks
Bob
Old Aug 26, 2006 | 09:54 AM
Patrick G's Avatar
My cam is pretty small, but SD tuning works great. But when a manufacturer puts their entire line on SD tuning that says a lot. Maximum fuel economy and lowest emissions are always concerns with OEMs. Bottom line, SD tuning can be as good as you make it.
Bob, I've used both HPT and EFI Live and prefer the tuner in my signature because of its broader capabilities and real-time tuning interface allowing changes to every parameter on the fly.
__________________
Old Aug 26, 2006 | 07:37 PM
Rothman's Avatar
Cool, I might go that route if anyone here is a capable enough tuner to do so.
Not to jack the thread or anything but, will running the stock Maf with a 90/90 combo effect Hp or Tq any great enough amount to justify Sd?
Old Aug 26, 2006 | 08:34 PM
Rothman
HumpinSS did a back to back dyno SD vs MAF. There was a slight difference in HP & TQ between the runs, but not enough to justify saying SD is better than MAF or visa versa.
The following threads may help you:
How the MAF works:
https://ls1tech.com/forums/showthrea...ight=maf+works
MAF vs SD on the dyno:
https://ls1tech.com/forums/showthrea...light=MAF+dyno
Tuning docs:
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
Also, the SD tuning link in my sig will give you an idea of what it takes to set up and tune in SD. The other link is to www.greenlightmotorsports.com Chad can get you set up with a WB and EFILive.
