Asp underdrive pulleys
Old Sep 4, 2006 | 06:22 PM
JstALs1's Avatar
Default Asp underdrive pulleys
I just got them in the mail and I need to get some belts for them. The instructions call for gates belts but i went to the part store and cant seem to find them. Any one with these pulleys running something different? I got the crank and alt pulleys. Also how did you guys get the brank bolt torqued down to 240 ft lbs.? cuz my wrench only goes to 180. Please help
Old Sep 4, 2006 | 06:50 PM
Sneakyws6's Avatar
On the tree
The torqueing sequence from SLP say to get it to 240ft/lbs then remove the bolt. Then use a new bolt and go to 37ft/lbs. Once at that setting mark the bolt and then turn the bolt 140 degrees.
I used a 3ft torque wrench in order to get mine there and still only got to maybe 100 degrees.
My SLP pullies said which belts to use and I got mine at Oriellys
Old Sep 4, 2006 | 06:57 PM
michael402z06's Avatar
it calls for a gates k060760 and k040378. heres what i did. the last 3 numbers are the length and the first 2 are the ribs. so the k060760 is 76 inches and the k040378 is 37.8. as far as i know all belts have this same coding.
Old Sep 4, 2006 | 08:20 PM
JstALs1's Avatar
Cool thanks that what i was looking for now instead of asking them i can just measure. What would happen if i didnt get it to 240 ft lbs ? I wish that the crank had a key way would make things so much easier. Since you have put them on have you had any problems?
