X,h,or Open Headers?????
Old Sep 9, 2006 | 09:38 AM
Wicked ls 1's Avatar
Default X,h,or Open Headers?????
My question is this I have a 382, at the track I remove the caps off the headers when I run. Would I pick up power with a H or X pipe or am I better of doing what Im doing?
Old Sep 9, 2006 | 05:03 PM
Old Sep 9, 2006 | 06:35 PM
GET_SOM's Avatar
maybe a foot or so of pipe off the headers... that may help with back pressure? is it a track only car?
Old Sep 9, 2006 | 06:59 PM
Speed Density's Avatar
hashtagBMW
Open Headers are going to flow the best out of all the choices. Adding anything also adds weight.
Old Sep 9, 2006 | 07:22 PM
RrCoX22's Avatar
backpressure and burning your O2's out is the only problem with open headers
and that fact that you need earplugs
Old Sep 9, 2006 | 08:50 PM
Car is street &strip the only time its open headers is at the track,or when the I want to **** some people off in the hood.Im runnin the flp headers with the off road pipe with cutouts before the y pipe.
Old Sep 9, 2006 | 09:53 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Not really backpressure as much as no velocity/scavenging.
Old Sep 9, 2006 | 09:55 PM
ChocoTaco369's Avatar
Tech Resident
i vote one of those X/H crossover pipes dumped. jmm98LS1 has one of them, maybe he can comment. should be the best of both worlds: improves power under the curve and scavenges pretty well.
 Michael S. Palmer
Old Sep 9, 2006 | 10:15 PM
Tainted's Avatar
X pipe will make the best possible power. at least with the x pipe it can balance uot the flow and as tis been said, help with scavening
Old Sep 9, 2006 | 11:36 PM
RrCoX22's Avatar
true... i don't know what i was thinking
backpressure is more involved when the pipe is kinked
Old Sep 10, 2006 | 04:43 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
IE: Sucky *** exhuast!
Old Sep 10, 2006 | 10:24 PM
Tech Resident
says who? y-pipes can scavenge better than an x-pipe. also, x-pipes are for peak horsepower. for dyno graphs they're great. unfortunately, you can't race dyno graphs. h-pipes have the ability to make more power under the curve and have a higher average gain over the entire rpm range. x-pipes make power over h-pipes way up in high rpm's. unfortunately, very little of our times is spent up there in those high rpm ranges that x-pipes rule in, making in my opinion an h-pipe or an x/h crossover a more realistic application.
i've only seen one graph of a car dynoed with an h-pipe and then an x-pipe. it was a mustang. the h-pipe **** all over the x-pipe. unfortunately, no one ever backs up their claims as to which is better. the reason why people praise x-pipes on this site is because that's what everyone has. nobody has proof they are better and they only get x-pipes because that's what most people have. i guarantee you if TSP made their system with an h-pipe instead of an x-pipe, people would praise the h-pipe. your best bet is to try each of them dumped and dyno each. Lord knows they're cheap enough. i'd put my money on the h-pipe making average higher power per rpm.
Old Sep 10, 2006 | 10:32 PM
ls1amit's Avatar
i got an h pipe talk about deep.
Old Sep 11, 2006 | 01:21 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It really isnt all that different. Most people could not tell what it was just from listening.
