question regarding bump stop and swapping shaft
If that sounds confusing let me know and I'll try and explain it better.
https://ls1tech.com/forums/showthrea...hlight=writeup
position on the shaft but should not be much.
Set the bumpstop by measuring the physical blade
position (dead center) and then adjust the TPS
position if need be to get the electrical result you
want.
If you have to, you can pad the bump stop back
up to prevent overtravel.
