Custom Header/Steering Column clearence
Old Sep 17, 2006 | 05:00 PM
canadaisintexas's Avatar
Lame Excuse for a Photog
Default Custom Header/Steering Column clearence
My car has a custom made header setup. The headers just barely touch the knuckle on the steering column which creates notches while turning as the header/knuckle collide at its widest point. I need to raise the engine about 5mm to stop this from happening. Does anyone make something that would allow me to do this?
Thanks guys,
Rob
Old Sep 17, 2006 | 05:08 PM
Order 66's Avatar
You will be better off heating up the header tube and clearance it. If you paid for those custom headers i would go back to the place first and have them redo them.
Old Sep 17, 2006 | 08:00 PM
They were a one off for a power adder done by hi-flo systems i believe. They were done about a year ago i believe for one of the previous owners. The reason i dont want to heat the headers and clearence is that would require me to pull the engine to get to them which is not something i really want to do as the rx7 is takin up all my garage space. The easiest thing to do would be raise the motor about 5 to 8mm
Rob
Old Sep 17, 2006 | 08:50 PM
Order 66's Avatar
You could put a spacer under the motor mount. But that is not what i would do.
Old Sep 17, 2006 | 08:58 PM
Would it cause any problems?
Old Sep 18, 2006 | 09:01 AM
V6 Bird's Avatar
yes.....
