Running without Thermostat
The thermostat is there to block the coolant from being able to flow thru the radiator, until the coolant reaches a temperature at which the thermostat is designed to open at. This allows the engine to heat up quicker for better performance. A colder engine also doesn't vaporize fuel as well, which leaves liquid fuel on the cylinder walls to wash off oil.
It's all in a way for emision. On a cold engine it runs richer to heat up faster, which increases HC and CO.
I wonder why ALL car manufactuers go to the bother of using a thermostat then if this works better. Guess they have no idea
King: St Juniper once said; 'By his loins shall ye know him, and by the length of his rod shall he be measured.'
Blackadder: "Something is always wrong, Balders. The fact that I am not a millionaire aristocrat with the sexual capacity of a rutting rhino is a constant niggle.
BTW - The TB by-pass mod doesn't make your car any faster either.
