Powerbond LS1/LS6
Old Sep 20, 2006 | 09:11 PM
Tony @ MPH's Avatar
Default Powerbond LS1/LS6
I can't find too many good pics of the powerbond balancers... the ones I can find show a bunch of holes around the center, which appear to be to help balance the balancer. Are any of these holes threaded for balancer removal? If not, I can't see how you would get those things off the snout!!
If so... well then, I would get one of these things just for the fact that I won't have to tinker around with a jaw puller when removing it.
Thanks
Old Sep 21, 2006 | 05:26 AM
00454sscamaro's Avatar
i got the one with all the holes.. and it wasnt easy to remove but it can be removed...
i thought from the looks of it it would be easier then the stocker, because of the threaded holes , but i couldnt get my puller to line up with them, and theres a lip on the pulley so even if they did the lip was still in the way.. i ended up using bolts in the non threaded holes then managing to get nuts behind the pulley started on the bolts, worked easy after i found bolts that didnt break.
