Spark plug/wires question.
Old Sep 21, 2006 | 09:58 PM
Onez4u2bn's Avatar
Default Spark plug/wires question.
Dunno if this is the right place to put it but I have noticed that only when it rains, my car when stopped, will start to jump a little. Kinda feels like I have a cam in it but I dont. One time the check engine light was flashing. I looked in the book and it said it may be a cylinder is down? It hasnt really done it that bad since but it does to it here and there. Any thoughts on why?
Old Sep 21, 2006 | 10:26 PM
Luna's Avatar
make sure you're plug wires are snapped all the way on. A flashing SES light means you are getting a misfire. WHen was the last time you changed your spark plugs? what about the wires? check it all out
Old Sep 21, 2006 | 10:35 PM
Onez4u2bn's Avatar
Never changed. I figured that was it. Sad to say but its been due. Just hit 81,000 miles to
Old Sep 21, 2006 | 10:36 PM
2002 SS #476's Avatar
A flashing SES means that there is the potential for the catalytic converters to be damaged. The misfire must be pretty bad. The best way to look at it is with a Tech 2 so you know what cylinder it is, then go from there. Or just try plugs and wires and see if that fixes it. There's a lot of things that can cause a misfire (fuel filter, plugs, wires, coil, etc...)
Old Sep 25, 2006 | 06:40 PM
Onez4u2bn's Avatar
Thanks for the info. I'm sure it's nothing a little preventative maintenence couldnt take care of.
