Painting The Exhaust...
Old Sep 25, 2006 | 09:35 PM
TORCHD 02 TA's Avatar
Default Painting The Exhaust...
I think that Jordan (orangepeel) did that.. So yes i am calling you out LOL..
How did you paint the exhaust? What did you use? Let me know.. i want to do this to mine as well it will look so much better
thanks
Old Sep 26, 2006 | 05:02 AM
300bhp/ton's Avatar
high temp engine/exhuast paint.
Make sure it's clean or it'll just flake off. Not keen on it myself.
Old Sep 26, 2006 | 06:49 AM
TheBlurLS1's Avatar
That's what she said...
I used this stuff, and now I won't use anything else. I found that Autozone actually carries it, bought 6 cans from them.
http://store.summitracing.com/egnsea...01988&D=301988
The flat black turned out really nice, and I didn't do **** to the tubing. I wiped off any dirt and let 'er rip. It went over the aluminized steel like it was primer'd.
Old Sep 26, 2006 | 08:41 AM
DirtyJohn's Avatar
I painted mine just recently.
Used 500* black engine enamel from Autozone, hopefully that will be enough.
I sanded with 240-400 grit all over, and a wire brush attachment around the welded spots.
Then washed it with a light Dawn solution, painted, let dry for a day and then re-installed it back on the car.
I read here somewhere that you can "cure" it by running a couple of warmup cycles @ 3:00 a piece spaced 30 minutes apart or so.
So I did that, looks nice now, not sure how well it will hold up tho, its only been a week or so.
Old Sep 26, 2006 | 08:42 AM
rocketman442's Avatar
I did this to my cappy 4 years and 60 thousand miles ago, no rust only some rock chips in it. Got the paint at the zone, cleaned the new pipes with a scotch brite pad and brake clean. looks great and the pipes don't rust. I did the same to my T/A also and it still looks brand new also.
Old Sep 26, 2006 | 08:51 AM
jmm98LS1's Avatar
I used the same stuff on my duals (only the silver variety) and the only "prep" I did was blowing the pipes off w/compressed air. Still looks like I just sprayed it.
Old Sep 26, 2006 | 09:43 AM
TheBlurLS1's Avatar
That **** is the ****.
Old Sep 26, 2006 | 01:30 PM
so casey you recommend the engine enamel paint.. i think that the 500* should work.. Also should i prime it first. or klean it off a bit and let er rip??
Old Sep 26, 2006 | 01:36 PM
Clean it and spray it
Old Sep 26, 2006 | 02:23 PM
schultzsj's Avatar
You need to use 1200 degree paint made for exhaust systems - anything forward of the intermediate pipe is almost certainly above the 500 degrees that engine paint is rated for.
I used silver exhaust paint from AutoZone on my Y-pipe and it still looks as good as (and quite similar to) the ceramic coating on my headers after two years.
Steve
Old Sep 26, 2006 | 04:03 PM
TheBlurLS1's Avatar
http://store.summitracing.com/partde...5&autoview=sku
That's what I used. It's WAY tougher than the *500 ****. Claims 1300-2000*
Just go to Autozone and look for "Flameproof VHT". VHT is a very high quality stuff, same stuff that Jordan used.
Old Sep 26, 2006 | 04:54 PM
jay_99z's Avatar
I've used the VHT stuff too. Put it on from the Ypipe back....with no pealing. Looks as good as when I first sprayed it. Only prep was knocking a little rust off with wire brush.
Old Sep 26, 2006 | 05:04 PM
Danny2tek's Avatar
get some black spray paint cans that are sold for painting b-b-q's
Old Sep 26, 2006 | 06:38 PM
this is what i am going to do
i bought today 1 can VHT flat black for the piping by the LTs to the H pipe. that will be more than 500* Then i bought 3 cans GLOSS black engine enamel paint for the entire car h pipe all the way back.. yes i will repaint the VHT with the gloss.
man that will look nice
Old Sep 26, 2006 | 08:55 PM
DirtyJohn's Avatar
Well this is fantastic, looks like my paintjob is screwed.
You know how many different ways I searched for painting exhaust too.
Too bad this thread wasn't up three weeks ago.
Old Sep 26, 2006 | 09:14 PM
lol sorry how did you do it??
Old Sep 26, 2006 | 11:14 PM
01 Red WS6's Avatar
Old Sep 27, 2006 | 07:54 AM
DirtyJohn's Avatar
I just used the 500* paint which apparently isnt enough.
so much for trusting the fat guy at AutoZone.
Oh well, so it flakes off I repaint it, im just getting tired of pulling this kit off and putting it back on.
Old Sep 27, 2006 | 08:14 AM
GuitsBoy's Avatar
For my headers, I used clear VHT flameproof 1200* (over the ceramic coarting).
For my exhaust I just used good old bar-b-que paint, with great results.
Old Sep 27, 2006 | 08:56 AM
TheBlurLS1's Avatar
....the 500* paint which apparently isnt enough.
This is why I keep preaching the VHT Flameproof. Engine paint works great on ENGINES because they rarely get over 230* (coolant temp).
I used engine paint on my rear end, but it's not tough enough for exhaust parts.
