TB bypass...
Old Sep 25, 2006 | 11:14 PM
71-Camaro-98's Avatar
Default TB bypass...
Is is true that if you do a throttle body coolant bypass you will get 5-8 hp more at the wheels??
Old Sep 25, 2006 | 11:17 PM
TransAminal's Avatar
Its possible if you compared a heatsoaked motor with TB bypass compared to one without, but that seems like an optomistic number. Under normal driving, it would probably give you 1-2HP max. You might see somthing like 5-8HP at the track on a hot day though.
Old Sep 25, 2006 | 11:19 PM
JEB Garner's Avatar
Not very likely !!!!
Old Sep 25, 2006 | 11:38 PM
98hardtopZ's Avatar
it just more or less slows down the heat soak on the tb...
Old Sep 26, 2006 | 12:19 AM
TheBlurLS1's Avatar
That's what she said...
I'm going to box up this can of worms before it spills further.
Will you notice it? Probably not.
Will it HURT? DEFINATLY not.
Is is nearly free? Yes.
Would I do it again? Yes.
