Duals with the relocated panhard bar?
Old Sep 26, 2006 | 12:40 PM
ls1snakebiter's Avatar
Default Duals with the relocated panhard bar?
Has anyone tried to run duals on both sides of the rearend with the bmr panhard relocator.
Old Sep 26, 2006 | 03:57 PM
TheBlurLS1's Avatar
That's what she said...
If you run duals on both sides, you won't need a PHR relocation. Orangeapeel has his done this way with the stock PHR.
The PHR relocation is for running both pipes over the same side.
Old Sep 26, 2006 | 05:58 PM
How? Isn't the braket that holds it on the left side on a stock panhardbar.
Old Sep 29, 2006 | 07:27 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You can't have the top rod in. I don't at least. I really didnt notice a change in handling with the stock upper phr gone.
Old Sep 29, 2006 | 08:36 AM
Default Re
How does it sound going all the way back in true dual fashion? what kinda of headers are you running? Also if you had some pics id like to see how you set it up if you don't mind
Old Sep 29, 2006 | 08:45 AM
2000WS6TA's Avatar
i had duals run over both sides and i neede an adjustable panhard rod and the shop made me a relocation kit. the driver side pipe wont fit over when the suspension has weight on it.
