Computer Reset after SES
Old Sep 27, 2006 | 12:32 PM
arctic2kss's Avatar
Default Computer Reset after SES
Searched, but couldn't find anything specific to my problem. Got P0154 and P0174, thus I changed the Bank 2 O2 sensor and car now runs fine. Will the computer reset itself after 3 successful heat cycles like it does for P0153 or do I have to manually reset it?
Old Sep 27, 2006 | 12:52 PM
zspot98's Avatar
You could always pull the BCM batt and PCM ign fuses turn the key to accesory and leave it for 5 seconds. Then turn the key off reinstall fuses and SES light should go away.
Old Sep 27, 2006 | 01:44 PM
Mr Incredible's Avatar
I take the battery cable off for ten-plus minutes. I lose the clock time, though.
Old Sep 27, 2006 | 02:31 PM
SoCalZ28's Avatar
if you let the computer do its cycles and reset itself it will still have those codes stored in memory. id pull the fuses to erase the codes
