new throttle blade for NW 90mm
Old Oct 2, 2006 | 11:00 PM
KRAZY K 2000 TA's Avatar
Default new throttle blade for NW 90mm
just like it says i need a need a new blade for my NW 90mm throttle body!where can i get one?got carried away with the drill.
Old Oct 3, 2006 | 02:23 AM
TheBlurLS1's Avatar
That's what she said...
Send a PM to "Nick Williams".
Old Oct 16, 2006 | 08:40 AM
ghettocruiser's Avatar
Just curious...why were you drilling into the TB?? Doesnt his throttle body already come with the hole that the FAST 90mm dont??
Im just asking because I just ordered a NW TB to replace my FAST one....and I thought it was good to go.
Justin
Old Oct 16, 2006 | 09:31 AM
SiL3NtXWS6's Avatar
it comes pre-drilled
Old Oct 16, 2006 | 07:37 PM
00454sscamaro's Avatar
got a welder? just take out the blade(dont weld it inside tb-many reasons not to ), weld it and drill to desired size.. unless the blades cheap to replace id just weld it or have some one weld it... like the others im also wondering why you drilled it?
Old Jul 1, 2007 | 07:52 PM
MY99TAWS6's Avatar
I drilled out my stock tb and wanted it smaller. I just put in a rivet and drilled it. Worked like a charm.
Also I have a pretty mellow cam 221/221/558/558/114 lsa but am having some idle problems should I drill it or not and will the screw do the same thing?
Old Jul 2, 2007 | 03:50 AM
transAm-98's Avatar
do these throttle boddies not have an adjuster screw?? I never took anything but a dremel to my TB. I personally don't see any reason for drilling. If you are really having problems than should look at how everything was installed and make sure it's right, or get it tuned.
