Cutout help needed
Old Oct 3, 2006 | 10:32 PM
Bossz28's Avatar
Default Cutout help needed
Ok so I have pacesetter Longtubes running to a ORY pipe to the borla. I already bought two weld on flowtech "3 inch Dia"
Here's my question should I stick with the 2 manual cutouts or should I go with an electric. The only thing that turned me off about the elec ones is that a couple guys in my f-bod club have them and all they do is complain. Half the time they never close and they scrap quite often.
My theory is that 2 is better than one. With 2 cutouts I could have true dual bascially, but would this be really noisy?
It's not terribly expensive for an electric but is it worth it or should I stick to the 2 manuals.
Old Oct 3, 2006 | 10:50 PM
ski23's Avatar
go electric. pretty damn convenient when ya want to rap it at some one. put 1 in the I pipe under passenger rear floor board and be done
Old Oct 3, 2006 | 11:03 PM
98camaroLS1M6's Avatar
If you didn't already have a flowtech cutout I would say go with a manual QTP stainless steel cutout for $45(ws6store) in the I pipe, if you ever decide to go electric, you can. Keep in mind- Two cutouts will make max hp at 6000rpms but the low-end tq will suffer when driving below 3000rpms. This is another reason people just do one, a little more backpressure. Since you already have the flowtech, stick one in the I pipe and be done. I think two is overkill, but if that's what you want, go for it.
Old Oct 3, 2006 | 11:22 PM
smokin t/a 600's Avatar
I think 2 is overkil also because you already have long tubes and an ory, you already have a real free flowing exhuast why spend more money on 2 cutouts when you can buy one and get the same if not better performance out of it.
Old Oct 4, 2006 | 01:00 AM
staringback05's Avatar
your fine with the two manuals....there not going to have sealing problems and break on you sometime....twos enough anyway
Old Oct 4, 2006 | 02:10 AM
Bossz28's Avatar
Ouch never thought about that. I heard of having too big of a exhaust system (diameter wise) will kill your bottom end. But I didn't put 2 n 2 together cutouts would have the same effect, makes sense. I could sale the cutouts on ebay, even if I couldn't I'd lose 50 bux big deal.
What is a good brand name for an electric cutout then. I'm staying away from ebay, ebay's great but I'd like to buy from a legit company.
I see jegs sells some.
Old Oct 4, 2006 | 04:12 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
2 cutouts isnt necessarily better by any means. A single cut-out is the way to go in most cases. But if you already have 2 I would stay manual.
Old Oct 4, 2006 | 04:27 AM
300bhp/ton's Avatar
2 comments.
1. Dual cutouts will bypass the Y pipe, this means you'll loose any benefit of scavenging. This is proven to make more power over duals with no cross over. However while running dual cutouts you will affect the exhuast pressure wave and if yo uare making over 400rwhp then you remove the restriction of the smaller I pipe.
You've probably got equal chance of making the same, less or more HP running dual cutouts. Only way to tell is to try it, although statistically the odds are 2 to 3 against.
2. You already have a cutout, it's called a Borla. Just run with the open plate and that's pretty much a cutout. Adding a cutout in the I pipe if you already have the open plate probably won't see any gains.
 Michael S. Palmer
Old Oct 4, 2006 | 01:37 PM
Bossz28's Avatar
Originally Posted by 300bhp/ton
2 comments.
It already is pretty loud, but I'd like to be a little louder for the track. I am running with a open plate. Just wondering, since a cutout is before the muffler the car should be louder correct.
What are some good electric cutouts on the market.
Old Oct 4, 2006 | 01:55 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You didn't say bhp! Shame on you!
Old Oct 4, 2006 | 03:59 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Talking
" but would this be really noisy ?? " .............
Old Oct 4, 2006 | 04:07 PM
Bossz28's Avatar
Well that's what I intend to do.
