NLP Billet PCV Catch Can, $74.95
Old 10-17-2006, 10:41 AM
  #61
Wyckedcamaro's Avatar
when can we get the blue color?
Old 10-17-2006, 05:55 PM
  #62
Benjamin Russick's Avatar
Mike,
How long will the intro prices last? I am up at my parents' and won't be back until next week. I'll be buying one as soon as I return. Ben
FWIW, Mike Norris did a great job with my H/C install and stands behind his work, so I have no doubt that this is a quality product.
Old 10-17-2006, 08:14 PM
  #63
Mike Norris's Avatar
Hi Ben,
Thanks for the kind words my friend. The prices are good till next Friday, the 27th of October, then up to the normal retail price of $84.95. Just call me next week. I will most likely be out of the shop Thursday afternoon, 10/26/06, until Monday Nov 6th as I will be out of town at the SEMA show in Las Vegas. Those e-mailing me orders to thevettedr@aol.com by midnite, 10/27/06, will recieve the special pricing.
Thanks and talk to you soon.
Mike Norris
Old 10-17-2006, 08:40 PM
  #64
black01_WS6's Avatar
If anyone needs help hooking up the catch can to their f-body can pm me. It was real easy. All you need is about a foot of 3/8 hose.
Old 10-18-2006, 06:40 AM
  #65
For everyones info, the latest cans and all future ones are shipping with 2 feet of 3/8" line and a brass 3/8" barbed hose connector for those who may need it. Also included are some general instructions I made up. Thanks again.
Mike Norris
Old 10-18-2006, 07:49 AM
  #66
Originally Posted by Mike Norris
Hi Ben,
Mike Norris
No prob, Mike. I will be away from my e-mail until Tuesday, so I'll have to try and call you. Talk to you soon! Ben
Old 10-18-2006, 08:26 AM
  #67
Restricted User
WS6nJAX's Avatar
what he said ^^^ will the color blue be available?
Old 10-18-2006, 10:13 AM
  #68
Runn's Avatar
Does it fit with FRC´s?
Old 10-18-2006, 10:53 AM
  #69
ZoomZ is checking on the colors and should post here soon I believe. As far as the FRC's, there is adjustment built into the can and it is just a matter of finding what works for certain applications. Hope this helps.
Mike Norris
Old 10-18-2006, 01:07 PM
  #70
marv's Avatar
Hey Mike, just wanted to see if my catch can shipped out yesterday. Just let me know when you can!
Sorry, guess this should have been a PM.
Old 10-18-2006, 01:54 PM
  #71
96-speed's Avatar
Originally Posted by =ZoomZ=
Mike will post up ordering info on monday when he gets into the shop .
Heres a pic of the can mounted in my vette .
I think you have it hooked up backwards. The air should flow from the bottom (entrance) out of the top (exit). It looks as if you have it hooked up so that the suction is pulling air out of the resivoir (full of oil).
Maybe I'm missing something?
Ryan
Old 10-18-2006, 02:07 PM
  #72
He has it put on correctly. If you take it apart you will find the filter is at the top, and the suction comes from the bottom. I can see where you are coming from though. I thought so as well, but after you get it and take it apart you will see.
Old 10-18-2006, 02:12 PM
  #73
96-speed's Avatar
Black01,
An earlier post from Mike Norris contradicts that:
The hose from the RS valve cover or the valley cover goes to the lower fitting on the catch can. The upper fitting goes to the intake port behind the TB.
To me, it seems like you would want to "suck" into the intake from the filtered side. Sucking into the intake from the resivoir doesn't make sense to me. I saw a pic of the disassembled can, and it still doesn't makes to me to suck from the resivoir .
My thinking is that ideally, you'd want to feed the catch can's resivoir with an unfiltered PCV line. Oil that doesn't make it passed the filter would be trapped in the resivoir, while filtered air would go up through the top and into the intake. Pulling air through the filter INTO the resivoir seems like it would simply saturate the filter until it becomes oversaturated and begins to drip into the resivior, leaving the intake feed pulling air from a resivoir full of oil - only relying on a 90º fitting placement to keep oil out of the intake manifold feed line.
Can you clarfy?
Old 10-18-2006, 02:51 PM
  #74
lets have Zoom answer this or Mike
Old 10-18-2006, 03:24 PM
  #75
wango-z-tango's Avatar
NON-Sponsor thread deleted by Admin. 1st and final warning.
Old 10-18-2006, 04:51 PM
  #76
Senior Member
Country Boy's Avatar
I think the other guy is saying that its backwards because of the way the AMW can is hooked up. On it, the VC goes to the top port and the side port goes to the intake.
Old 10-18-2006, 04:59 PM
  #77
speed_demon24's Avatar
I'm glad I held off on buying a cheap one, looks like I'll be ordering one next pay check.
Old 10-18-2006, 08:53 PM
  #78
My apologies, board, and Mr. Norris in particular. The original intent was to post a "press release" sort of thing to this board, which in retrospect is improper, to hijack a sponsor's thread.
We are working toward a sponsorship here on ls1tech.com, and I will post in a new thread in an appropriate place at some time in the future.
With sincere thanks,
wango-z-tango from ls1gto.com, and an avid lurker here
Old 10-19-2006, 09:47 AM
  #79
=ZoomZ='s Avatar
This can was designed to take cv from the valve covers into the top of the can .
The oil vapors come into the can , hit the filter and turn the vapor into a liquid , inturn droping the liquid downwards while the remaining air returns upward and out the side hole in route to the intake manifold .
If you take the cv into the side of the can the oil vapors turn downwards
slightly untill it reaches the snout inside the can , turn upwards and hit the filter , going this route will constantly be pushing oil vapors upwards through the filter and out of the can .
The filter material is used to congiel the oil back into some what of a liquid state .
I would estimate that it turns about 95% of the vapors back into a liquid form.
I hope this clears things up a little .
Old 10-19-2006, 11:42 AM
  #80
Yes it does. Thanks,
Quick Reply: NLP Billet PCV Catch Can, $74.95
