Help! Throttle body question.
Old Oct 10, 2006 | 07:13 PM
KdubFL's Avatar
Default Help! Throttle body question.
I have a stock T/B off of an 01 GMC 4.8 that i'm trying to get rid of. I cleaned it and ported it. Does anyone know what size this thing is? Part number? I just want to know if it is LS1 compatible or not. Tried getting some answers from the truck site but they haven't been much help. Thanks for any info you can provide.
Old Oct 10, 2006 | 09:35 PM
v8's Avatar
v8
17,16,15,14,13,12,11 Drvr
the car and truck t/b are the same with different spring on the side of the t/b, there all 78mm stock. good luck on the sale.
Old Oct 11, 2006 | 10:51 AM
KdubFL's Avatar
Ok, thanks. I was thinking that I wouldn't get an answer.
Old Oct 11, 2006 | 11:03 AM
2xLS1's Avatar
That will interchange the closest with the 98-99 f-bodies as it has the same cable cam as those. 00-02 f-body cams are different. The coolant tubes on the bottom and the fresh air tube on the top are slightly different than on all the f-body T/Bs. They are all 75mm.
Old Oct 11, 2006 | 07:42 PM
Bo White's Avatar
Yes 75mm, it has the 70125 blade which is identical to the Fbody blade except a .145" bleed hole were the car blade has a .165 hole.
