How are QTP/KOOKS ??
Old Oct 16, 2006 | 01:01 AM
00Formula00's Avatar
Default How are QTP/KOOKS ??
So i have been reseaching a lot about Dynatech Supermaxx and how easy they are to put in...
How bout the QTP LT's, any one had easy installation?
Anyone run into problems?
I'll take KOOKS feedback too if anyone has it....
thanks
Old Oct 16, 2006 | 01:22 AM
00454sscamaro's Avatar
well my kooks werent easy to install but there also the biggest size avalibe (that i could find) 1 7/8 stepped into 2. only the drivers side gave me issues -needed to trim fat off the k member and jack the engine up 3 or so inches.. im sure the smaller sizes would be alil less work.
Old Oct 17, 2006 | 10:41 PM
Sawz-All do the job???
Old Oct 17, 2006 | 11:14 PM
BirdmanLS1's Avatar
Hey, I have QTP LT's... the install was an absolute terrible experience. The thing is, im pretty sure i didnt jack the car up high enough to get the right angle to slip the driver's side header in. I also think i got one of the headers from a bad batch of them sent out last spring. For some reason that one batch had alot of complaints but overall im glad i went with QTP's. I only have the LT's and exhaust and i have 334 hp, 345 tq untuned so those are some good numbers.
Oh and btw, dont get their ORY if u are lowerd. I had the sportlines on my car and i literally had 1 inch of clearance with their ypipe w/cutouts.
I have heard that kooks is a very easy install so they are always a good choice too... id go with qtp's if i were u tho.
Old Oct 17, 2006 | 11:17 PM
99'Formula's Avatar
On the Kooks, 1-3/4 slide right in, any bigger you might run into installation problems. I have 1-7/8 and had trouble with the drivers side. Other than that year and a half down the road and they are still excellent. No Rust and they look purdy. Good luck with the decision.
Old Oct 17, 2006 | 11:25 PM
to birdman LS1, if you had been doing the work on a lift and had a good batch, you think the installation would have gone better?
The only reason i haven't gone KOOKS is because i don't know that they have a catted ypipe, and if so is it 3"?
Old Oct 18, 2006 | 12:32 AM
BirdmanLS1's Avatar
yes if u had a lift it would be cake. And yes i am almost 100% positive that kooks has a 3'' catted y-pipe. QTP does have one as well but i think neither of those y pipes have good clearance. Kooks would have more so if anything i believe. Thats just from what ive seen. I would get some catted tru duals if i were u .
Old Oct 18, 2006 | 12:40 AM
Xtnct00WS6's Avatar
It's hard to be the QTP's. I believe they even come polished too! Just make sure you do it right the first time and get stainless.
Old Oct 18, 2006 | 01:29 AM
ya right now thats where i am deciding which is going to be easier to install the QTP or KOOKS and then i will go with there headers and catted y....
Old Oct 18, 2006 | 01:59 AM
Frans96SS's Avatar
KOOKS hands down...... ive installed plenty and they fit perfect and slide right in......
Old Oct 18, 2006 | 02:43 AM
BirdmanLS1's Avatar
if that were the cast then go with kooks, but im tellin u, u might regret going with their y pipes... i spent $600 on my qtp with dual cutouts and now they're gonna be gone in less than a few months...
Old Oct 18, 2006 | 02:54 AM
BuBbABFP's Avatar
Qtp! Very nice headers.
Old Oct 18, 2006 | 07:16 AM
omcar's Avatar
Default Why not coated Pacesetters with the TSP catted y-pipe?
Seems that with all the discussion re Kooks, Dynatech and QTP which are supposed to be the best, I could save the $500-$600 and go with coated Pacesetters. What am I missing? Getting confused with the decision..Thanks
Old Oct 18, 2006 | 07:54 AM
Frans96SS's Avatar
you get what u pay for... plus coated headers suck..... eventually they will rust.... i had a customer come into my shop with a set not even 6 monthes old and the egr tube was broken off his header......
Old Oct 18, 2006 | 09:01 AM
omcar's Avatar
Default So which would you get?
Frans 96 SS..Where in PA are you in PA.? I'm in Pa. as well.
Old Oct 18, 2006 | 09:08 AM
n20stroker's Avatar
QTP all the way!!! Install was cake did it at home. Jacked the car up and put jack stands under the car. Had to remove oil filter on driver side. Well worth the money.
Old Oct 18, 2006 | 09:11 AM
omcar's Avatar
Default Best price for the QTPs?
Where did you get them? Thanks
Old Oct 18, 2006 | 09:59 AM
N20 stroker....is that all you had to do, remove the oil filter? Didn't have to cut the k member or remove the steering shaft?
Old Oct 18, 2006 | 10:05 AM
n20stroker's Avatar
No I had no problem with them hitting. I had a new batch some of the old ones you needed to trim some ****, but wit the new batch the tubes are tighter together. My friend just installed a set about 2 weeks ago on a lift he said it took alittle more then an hour to do soo far he loves them.
Old Oct 18, 2006 | 04:04 PM
i borrowed my dad's plasma cutter. i still need to go back and grind alil on the passenger side.. it was cake getting it in, but now that its tightened its sitting against m k memeber, not close its actually on it touching pretty good.
heres some pics-
awaiting to go in my car..
passenger side-hard to see where its touching but if you know what the k member looks like from that angle you can figure it out easily.
drivers side- where i cut was only to get it to go in, now the close part i dont know if im going to cut to give more clearance or not. plan to get new k member down the road anyway.
