Race only exhaust set up, would this work?
Old Nov 5, 2006 | 06:33 PM
  #41
Jeremiah's Avatar
Originally Posted by ChocoTaco369
if you're running 9's, you can probably get away with it as the added backpressure would probably hurt you. what you have is a very unfair comparison. for the normal board members - the guys running 12's and 13's - they're better off with a type of midpipe that scavenges.
The thread title says "Race only", the normal board members running 12-13 sec. times wouldnt know mutch about that.
All combos will react differently to different mods, the only true way to know if it will help you is to try it. The old school guys have been doing this for ever and have gotton good results from it. Most of the guys running 3" true dual set ups have over killed there needs. I would say if your not at least dipping into the tens dont waist your time with a set up like this.
Old Nov 5, 2006 | 09:13 PM
  #42
Matt D's Avatar
Retired Street Racer
Originally Posted by General Jack
Matt D - thanks for the info which was relevant to the question I had in my original post - and that some failed to consider before flaming. It sounds like for my race set up, using bullet mufflers and turndowns off the headers will yield a nice hp pickup over my current set up (2.5" y-pipe and Borla catback).
No problem man, anytime. I am here to help my fellow LSX enthusiasts, as well as learn from what others have done.
By Brett Foote | 2026-06-04 05:00:17
