Squeaky belt, belt lube=a bad idea???
so has anyone put lube on the pulleys? i read anotehr post where someone used WD-40 and it worked for a while but it came back. so another person suggested a silicon lubricant. anyone try it?
i have the same problem and i haven't narrowed it down either. i heard the squeak after i had to change the tensioner pulley. if you spray the smallest amount of WD40 or silicone lube it shuts right up for a while but it just comes right back. it was worse when it was cold but since it has warmed up i haven't heard it as often.
