Rocker arm ratio
Old Nov 8, 2006 | 08:59 AM
1hotls1's Avatar
Default Rocker arm ratio
I've been told that my wot misfiring and backfiring may be caused by loose rocker arms. Is it common on head and cam cars to have to remove the valve covers and tighten later after installation? If I have to remove the covers, would it be worth while to install new rocker arms with a different ratio? What is stock ratio and what would be best with my Lunati 218/221 cam?
Old Nov 8, 2006 | 09:22 AM
Tainted's Avatar
whens the last time you did a tune up?
Old Nov 8, 2006 | 09:41 AM
1hotls1's Avatar
Default Tune up
Installed new wires and plugs about 4000 miles ago. I don't think that it is a firing problem. I had a bad plug once and the car missed and backfired at every speed and throttle position.
Old Nov 8, 2006 | 09:57 AM
Tainted's Avatar
mmmk so we've ruled that possibility out then.
