Meziere Water Pump
Old Nov 8, 2006 | 07:33 PM
TWINK's Avatar
Default Meziere Water Pump
Would the 100 series Pump (35gpm) Be ok to run on the street. ?
Old Nov 8, 2006 | 08:16 PM
nikon1999's Avatar
i have the 55gph series i just put in my car, idle temps are a little lower than stock pump w/160 t-stat, but decent highway trips it gets hotter...i personally wouldn't feel comfortable with the 35
Old Nov 8, 2006 | 10:46 PM
TWINK's Avatar
I just got a good deal on the 35...
Old Nov 9, 2006 | 12:10 AM
BirdmanLS1's Avatar
I just installed the 55, So far i love it. Idk much about the difference between the 35 and the 55 so i couldnt tell u, cept i love mine already.
Old Nov 9, 2006 | 12:13 AM
TWINK's Avatar
Ive got $275.00 in mine so not a bad deal i saved over $100.00 i hope it's worth the $$$ over Power...
Could you tell any difrance from the stock to the electric pump ?
Was it a pain to install ?
Old Nov 9, 2006 | 01:35 AM
BirdmanLS1's Avatar
It was not at all a pain to install. This is the first mod ive done on my own and im by no means a mechanic. Im not sure if ur pump is the same install as mine, but ls1howto.com has a very nice write-up on the EWP. I just followed their directions and it worked perfectly the first time. Im also suuuch a noob when it comes to wiring and i got that right the first time too so im pretty excited.
Old Nov 9, 2006 | 01:36 AM
BirdmanLS1's Avatar
I can tell a difference in the temps it runs at, and it has a bit more power, but its not too noticeable. Plus i will be wiring a manual override switch so i can keep my car cool in the staging lanes at the track.
