Breather cap
ive looked at autozone and all over and found one on some of the websites but where can i get a breather filter that screws right into the oil filler cap??? i have one on now but its the full metal one with holes at the bottom that you can get at autozone. I want the kind that is a wrap around filter and screws right in no problem.
im guessing this is what your looking for at the bottom of the page...
http://www.thunderracing.com/catalog...vid=3&pcid=276
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by texinteg
Why not just drill a one inch hole in the top of you oil fill cap and use a push in style breather with some rtv to hold it in place?
Originally Posted by Z28LS1camaroguy
yeah thats the kind of breather but i need to find one that screws right into the oil filler neck.
I can't believe you guys don't know about these..
LS1speed has JUST what you want.. I just got mine. They have the helix to mount to your valve cover..
Down towards the bottom..
http://www.ls1speed.com/catagory.cfm?catagory=Engine
I hope you fellas know that if you have a near stock LS-1 & install one of these breathers you will screw up Chevy's closed system & cause a loss of acceleration~gas mileage~vacuum ie , performance.
well thats odd that alot of LS1 guys do it, if its useless then why do they make them?? ive had no problems and no loss of anything so i dont see where you are getting it will screw **** up.
Well he just isnt making sense, alot of the older muscle cars use breathers and there are quiet a few guys on here who delete there PCV systems and run breathers with no problems at all, i dont see where he is getting his info.
