which intake do i need
Old Nov 12, 2006 | 06:28 PM
bouncnbars's Avatar
Arrow which intake do i need
Hey guys, need some help. I have an '04 Tahoe with a 5.3. I want to put the fast 90mm intake on it, but I'm not sure if it will bolt up. It is a GENIII engine so you would think that all ls1 parts would bolt up to it. I have people telling me that it's like FORD and that the parts are just barely different from the ls1 to everything else. This is gonna go on my patrol truck, me being a cop, cause I'm tired of taking 1.5 miles to catch someone. Let me know what ya'll know. Thanks.
Old Nov 12, 2006 | 06:57 PM
sroach20's Avatar
http://www.performancetrucks.net/for...s6+intake+swap
Old Nov 12, 2006 | 07:23 PM
Tainted's Avatar
we'll help you if ya promise not to pull us over
Old Nov 12, 2006 | 07:40 PM
Ace$nyper's Avatar
They will let you do that?
I agree hit up that LS1/LS6 before you pop for a FAST unless you have other work to warrent a FAST setup.
Old Nov 12, 2006 | 08:43 PM
Louie83's Avatar
Nitrous would help you catch someone a lot easier.
Old Nov 13, 2006 | 08:18 PM
bouncnbars's Avatar
well i'm about to take it to lgmotorsports for apr heads and a custom cam, lifters, rods and springs. the best set of headers i found are shortys by gibson. i keep getting told they don't make long tubes for my truck.
Old Nov 13, 2006 | 09:27 PM
sroach20's Avatar
PaceSetter now offers quality-made, affordably-priced long tube headers for full-size light duty pick up trucks and SUVs. pacesetter 72C2265
CNC-machined 3/8"-thick steel flanges are matched to exhaust port profile for optimum seal and flow.
• Flash-controlled 16-gauge carbon steel primaries provide greater durability than light gauge stainless steel.
• Length and diameter of mandrel-bent tubing is optimized for flow and best performance increase.
• Tubes enter collector in proper sequence for maximum scavenging.
• O2 sensor fittings on all applications.
• Complete with necessary gaskets and fasteners for installation.
• Made in USA
• Affordably priced
• Off road use only.
ARMOR*Coat, 99-05 GM Silverado/Sierra 1500, 4WD, 4.8L/5.3L, Long Tube
just got mine with the off road ypipe for $500 shipped.
Old Nov 14, 2006 | 11:29 PM
bouncnbars's Avatar
hell yeah. thanks man. and 500 is cheap for headers, y, and shipping.
Old Nov 15, 2006 | 01:13 AM
taintedmeat's Avatar
If I ever pass through Burleson I'll be on the lookout for a white unmarked Tahoe
Your district/precinct/county lets you modify your vehicle? Do you have to do anything special to get permission to do so? Seems like a lot more guys would mod their Crown Vics if it was acceptable at more precincts. I know I would if I was a cop. True duals and lt's on a 4.6 Crown Vic
Old Nov 15, 2006 | 03:29 AM
Cop Car's Avatar
a FAST intake on a stock motor is a huge *** waste of time.
you should start out with exhaust, long tube headers and true duals for maximum performance. then you should start thinking about a stall converter, it will turn your truck inside out, no joke, it would probably cut your 0-60 time nearly in half. after you have headers and a stall. an LS6 intake would probably be your next mod. then after you have all that look into a cam and lastly heads THEN come back and think about a FAST.
and to answer your question.. you would need get an LS1 water pump because it has a lower profile. the truck intakes TB sits up much higher than the LS1s. after you switched your water pump you could then use a LS1/6 or FAST intake
Old Nov 16, 2006 | 04:21 PM
bouncnbars's Avatar
well since i own the truck, they can't tell me what i can or can't do to it. now the city vehicles, you would first have to justify the mod to your sgt., then your lt., then, your captain, then your assistant chief, then the chief, and even then, they probably won't let you do it. county cars, you would have to go through the same process except for a chief and assistant chief, you have constable and chief deputy and sheriff and chief deputy, after you go through all that crap, you now get to go to comissioners court and justify the mod to all the commissioners, these guys are dicks, they controll how much money you get each year and just about everything else. the only thing they can't do is tell us what to do as police.
Old Nov 16, 2006 | 04:49 PM
Cop Car's Avatar
hmm.. well IMO your best option since you own the truck is to sell it
then somehow aquire a Trailblazer SS, you can get a new one with no options for around 30k.
put some headers and an intake on it and you have a very solid 12 second truck.
Old Nov 16, 2006 | 05:35 PM
bouncnbars's Avatar
when i bought the tahoe, they had a trailblazer ss for 36k. all wheel drive. i just couldn't justify it to myself. i olny payed 16k for the tahoe. i figure i can put 20k in the tahoe and spank the hell out of the trailblazer.
Old Nov 16, 2006 | 06:56 PM
Cop Car's Avatar
honestly... it would be close.. bone stock they have been known to get into the 13s. your 'ho is probably a 17 second truck..
16k isnt bad for a 'ho. does it have a 6.0 (on an unrelated note, that rhymes). if you have the 6.0 heads and a cam will really wake that motor up.. and would be in the $4,000 range.
Old Nov 16, 2006 | 07:39 PM
bouncnbars's Avatar
no, it's a 5.3L
Old Nov 17, 2006 | 01:25 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Heads/Cam/FAST.... I bet that would wake that motor up quite a bit!
Old Nov 17, 2006 | 10:59 AM
evrae205's Avatar
ls6 intake and headers would make a world of difference on that 5.3.
Old Nov 17, 2006 | 11:01 AM
evrae205's Avatar
ya but a lot of cheese. lol
Old Nov 17, 2006 | 11:43 AM
bouncnbars's Avatar
i talked to lgmotorsports. they are recomending the blower with heads and cam to match. better all around driveability.
Old Nov 17, 2006 | 01:15 PM
bouncnbars's Avatar
hey orange, when my truck is done, i want to race just to see how it'll stack up.
