getting ready to install Pacesetter LT's. any advice?
Old Nov 13, 2006 | 11:15 PM
BatmobileSS's Avatar
Wear gloves. My hands were cut up pretty good from my install.
Old Nov 14, 2006 | 12:25 AM
sykotic's Avatar
My pacesetters showed up @ 4pm today, I had started takin stuff off @ 2, I got done removing the AIR system, both stock manifolds/cats, and stock y-pipe(which was welded to my catback) at around 6pm, taking my time of course and alone. Friend showed up and we got everything done and tidy and fired her up at 9pm.
I had 0 issues, I did it on ramps on the front with the rear on jack stands, didn't have to cut or grind anything to get the headers up there and bolted.
Comes with new header bolts and copper gaskets, which I used. I also bought 2 24" O2 extensions which you will need. Only other things I would say to get would be spark plugs since you're there and its so easy, just change them out after you remove your old manifolds cause you can easily get the LT's up there with spark plugs in place. If you will allow the engine to cool the bolts break loose much easier, I started with it warm and it was a bitch, the passenger side went so easy cause I did it later when the engine was cool.
That dipstick I was stumped on for a bit but you pretty much just yank on it real hard straight up and it will eventually come right out, oh yea after you remove the 15mm bolt that bolts it to the head. It wasn't near as bad as I thought it was going to be though, very quick and easy considering how slow I did everything.
Old Nov 14, 2006 | 12:26 AM
sykotic's Avatar
I can't agree more, I got all the stock stuff removed without a scratch just some rubbing so I had red marks and I was gonna come up on LS1Tech and brag about how there was no blood shed, then I went to change my plugs and my hand slipped and I got this 2 inch long gash down the length of my middle finger, pretty deep too. Hurts so bad... I wore a glove the rest of the install and it made things much easier.
Old Nov 14, 2006 | 12:32 AM
BirdmanLS1's Avatar
ive probably had the worst experience installing headers ever... but i wont get into that. funny thing is the dipstick was the least of my problems... lol. Make sure u get the car off the ground and do like that one guy said. Point ur collector downward and push up and rotate as u go up. This is for the drivers side header BTW. Passenger side header is a breeze. Ull need o2 extensions for the front and stock GM metal gaskets are the best and most recommended on this site.
I had to jack up the motor, grind stuff, cut stuff, hone out the bolt holes on the header, adjust the steering rack, take out the filter, etc etc... all in all took 3 days... but thats a rare occasion with a bad batch of QTP headers... o well. Hopefully yours will go alot more smooth than that.
Old Nov 14, 2006 | 12:38 AM
sykotic's Avatar
Oh yea I took off the steering knuckle or whatever it is you call it, plenty of room to put it back after you get things bolted up. Don't forget anti-seize on your bolts.
Old Nov 14, 2006 | 06:15 AM
Function>Form's Avatar
yea i understand that...im just wondering if im going to need o2 extensions and the ****** o2 sim
Old Nov 14, 2006 | 07:38 AM
sykotic's Avatar
yes you need the o2 extensions unless you're okay with extending the wires by cutting and splicing them with the crap provided by pacesetter. o2 sims you will need if you aren't getting the codes deleted by someone with a tuner, or you can deal with the SES light.
Old Nov 14, 2006 | 03:36 PM
presto_z's Avatar
instead of extending my o2 wires or buying the o2 extensions i bought 2 bosch 13111's corvette rear o2 sensors from a member on here....
Old Nov 14, 2006 | 03:53 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
YEAH..no need for extensions with these 'cause the wires are much longer.
Old Nov 14, 2006 | 06:54 PM
2001bluerata's Avatar
Sorry to steal the thread, but are the bosch 13111's you are talking about being used for the front o2s?
Old Nov 14, 2006 | 07:43 PM
presto_z's Avatar
yes... they are
i have no rear o2... just the fronts.. rear o2 have no effect on your engine performance... just get the code tuned out (or get sims), and have the AIR/EGR code tuned out at the same time
sims sometimes still throw codes....
Old Nov 19, 2006 | 02:35 PM
  #32
smf_ss's Avatar
where can i buy the bosch 13111's?
Old Nov 19, 2006 | 03:52 PM
  #33
presto_z's Avatar
ill shoot u a PM with the name of the member i got them from
Old Nov 19, 2006 | 05:00 PM
  #34
FireSilverLullaby's Avatar
anyone baught the slp installation kit? http://www.marylandspeed.com/product...roducts_id=152
Im getting ebay headers and i dont thinkt hey come with bolts, or could i just reuse my old ones.
