What mods to do to a set of Mac headers??
Old Nov 28, 2001 | 09:51 AM
Kilroy's 99 TA's Avatar
Default What mods to do to a set of Mac headers??
I'm getting a set of used Macs (finally!) and I know alot of guys do some tweaking to them, what should I do before putting them on the car?
(these will be with the ORP)
Old Nov 28, 2001 | 10:04 AM
TA_2001's Avatar
Default Re: What mods to do to a set of Mac headers??
Here is an old thread that I saved.. about
a mod on MAC's
http://ls1info.com/article.php?sid=108
Do the AIR Restrictor Mod as well..
Old Nov 28, 2001 | 10:05 AM
DRGnFLYZ28's Avatar
Based on what I've read, you can port & smooth out the ports on each primary tube. I've heard they may have some metal in there that hinders flow. I guess a good port match would help.
Oh, and Jet Hot coat them! I had a MAC y-pipe on my 94 Z and the coating was ok but if I did it again, I'd go Jet Hot.
Good luck!
Old Nov 28, 2001 | 10:20 AM
Red99Hawk's Avatar
[quote]Originally posted by DRGnFLYZ28:
<strong>Based on what I've read, you can port & smooth out the ports on each primary tube. I've heard they may have some metal in there that hinders flow. I guess a good port match would help.
</strong><hr></blockquote>
How much does this porting cost? Im thinking about getting this done on mine...anyone know?
Old Nov 28, 2001 | 10:25 AM
DRGnFLYZ28's Avatar
I have an air/die grinder and compressor but you can run out and buy a Dremel (pretty cheap) and do it yourself.
Old Nov 28, 2001 | 01:24 PM
2K2 LS1's Avatar
I ported my set for the 01' basicaly took out most of the inner weld on the primaries. It was pretty sloppy. I don't know what differnece it made, but I am sure it was worth something. Some people modify them to eliminate the air tubes. And alot of people are making their own custom 3" y pipe.
Old Dec 3, 2001 | 09:38 AM
Is it true that with the ORP the headers are really terrible sounding? anything short of putting CATs back on to correct this?
Old Dec 3, 2001 | 09:47 AM
CHRISPY's Avatar
Install bullets in the Ypipe. You can also expand the collectors or cut them off, extend the collector a little and put in a 3 inch collector. That has picked up 6 or so RWHP on the dyno I think.
Chris
 Michael S. Palmer
Old Dec 3, 2001 | 04:35 PM
jmX's Avatar
jmX
Ported before/after:
http://jmx.car-audio.net/car/macs.jpg
