poly mounbt or solid mount?
Old Dec 12, 2006 | 05:45 PM
CamaroSS621's Avatar
where do you buy poly engine mounts???????
Old Dec 13, 2006 | 01:34 AM
TheBlurLS1's Avatar
That's what she said...
Thunderracing.com check the "Bushings" section.
Old Dec 14, 2006 | 05:56 PM
psygkosis's Avatar
I've been asking similar questions lately as well. I'm not cammed and don't really need to go solids but I'd prefer to do this once and forget about it so I've decided to go with the solids. Here's a link to my recent thread that you may find beneficial. If you do go solids post up how it goes.
https://ls1tech.com/forums/suspension-brakes/621393-solid-motor-mount-questions.html
thanks guys Ill be ordering some solid ones this week. I can still go with a poly trans mouth correct or do they make a solid trans mount as well?
Any input on this? It's what I plan on doing as well. I heard solid/solid is very bad???
Old Dec 14, 2006 | 07:07 PM
TheBlurLS1's Avatar
I would do a poly trans mount, with solid motor mounts. I noticed quite a bit more vibrations going from stock to poly, can't imagine if it was solid.
