Solution to FRA IAT problems
Old Nov 26, 2006 | 06:53 PM
TX01Z's Avatar
Default Solution to FRA IAT problems
see pic
After adding an auto trans cooler, my IAT's were sky high. To maintain the FRA enhanced intake area, drill 1 3/8 in. holes through lower airbox floor and through the hollow brace. Fill the FRA cutout area with insulating material to lower IAT's over the stock setup. Overall result, lower IAT's and increased intake area.
Old Nov 26, 2006 | 07:04 PM
TX01Z's Avatar
pic here hopefully
Old Nov 26, 2006 | 07:05 PM
TX01Z's Avatar
here it is
Old Nov 26, 2006 | 07:11 PM
Tainted's Avatar
that kinda no envermind i wotn start
sorry but thats just stupid
Old Nov 26, 2006 | 07:15 PM
TX01Z's Avatar
Increased intake area vs the stock slot opening. Better insulation from radiator heat. Figure it out.
Old Dec 29, 2006 | 05:10 PM
radz282003's Avatar
Not criticizing, but I just wanted to ask if and how you verified the decrease and under what circumstances. I'm am looking into the same thing, and just wanted to verify before I cut holes into the structure that holds the front of the car together. Again, no negative intent.
Thanks
Old Dec 29, 2006 | 10:51 PM
rich Z's Avatar
If the front of your car falls off then you definately will have lower iat's with all that air coming thru.
Old Dec 29, 2006 | 11:27 PM
oange ss's Avatar
not a good idea to drill the core support, especially holes like that
Old Dec 30, 2006 | 08:20 AM
WILWAXU's Avatar
Hehe.. I've seen MUCH worst done to the core support
