just bought a set of long tubes
Old Dec 5, 2006 | 02:39 PM
ChocoTaco369's Avatar
Tech Resident
Originally Posted by Cop Car
yes, and it ran fine before. if you switch to synthetic after running certian dinos you have the potential for ruined motor. you should pick to run regular or synthetic and then stick with it.
you should seafoam your crankcase before you switch from conventional to synthetic oil to get all the gunk out. at least that's what i recommend. switching should not hurt anything at all. in your case, we can only speculate what happened, but people should check their oil levels, heck ALL FLUIDS, frequently anyway. this is usually why cars owned by men last longer than cars owned by women.
Originally Posted by TORCHD 02 TA
ahhhhhhh Anthony, i am not the only one lol.. there was another guy that had the same damn problem. he was running M1 5W30, he switched to GC 0W30 he said his car was loud ticking like crazy. he switched back no prolbmes.... See i am not the only one
BTW let me rephrase that. the GM Manual call for 5W30...
GC Problem.. User #2
you also have to remember that increased noise does not necessarily mean increased wear. even if your engine is twice as loud on GC 0W-30 than M1 5W-30, i still bet you'll come away with nearly half the wear on GC 0W-30. my engine has a tick to it, too, but nothing that worries me. i intend to get this oil change analyzed. i have something like 800 miles to go before i hit the 4,000 mile mark. i'm considering running it to 5,000, but not sure yet.
i just sent away for the kit right now from blackstone
Old Dec 5, 2006 | 02:53 PM
loyolacub68's Avatar
Where can you get the german castrol?
Old Dec 5, 2006 | 03:41 PM
blkbird's Avatar
Auto Zone. It has seemed to go up in price though. Its up to 5.99 a quart!!
Old Dec 5, 2006 | 04:00 PM
Tech Resident
yea i was informed about a price increase a few months ago. i guess it finally hit the shelves bye bye $5.49. i guess i'll be paying the same as mobil 1 ripoff prices
Old Dec 5, 2006 | 04:25 PM
cobrakiller221's Avatar
I did the sea foam treatment on my car last friday and I am switching to gc 0w30 this weekend after I run thrugh this tank of gas. My oil should be very nasty when I change it. First sea foam. Car has 90k miles on it
Old Dec 5, 2006 | 07:56 PM
TORCHD 02 TA's Avatar
Anthony, you could be right. But that noise was really loud. I guess i was afraid that i might hurt my baby... But the noise was a lot louder with the GC! Like i have said before, GM calls for 5W30.. why switch????
Old Dec 5, 2006 | 07:57 PM
if you pick it up at the ZONE... make the GC oil on the back says 'MADE IN GERMANY"
Old Dec 5, 2006 | 08:59 PM
silverLS199's Avatar
so whats the smartest safest thing to do
Old Dec 5, 2006 | 09:23 PM
Tech Resident
because it's junk. i'd try and get 5W-40 if you can find it. it's a better oil. remember, mobil 1 5W-30 is barely a 5W-30. the 5W-40 is more on par with our larger clearances. mobil 5W-30's a 4 banger oil...though i still wouldn't use it.
Old Dec 5, 2006 | 09:33 PM
then i will try and find the 5W40 then
Old Dec 5, 2006 | 10:16 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Mine was normal looking. Don't know what the deal was. It smoked like a columbian drug lord.
Old Dec 5, 2006 | 10:17 PM
  #32
ЯєŧąяĐ Єl¡m¡иąŧøя ™
10w30 Mobil 1 in the SS and 10w40 Castrol in the Z28. I have not had problems.
Old Dec 5, 2006 | 10:24 PM
  #33
Tech Resident
get 'em analyzed. you won't know until you get it done. maybe i'm paranoid, but i plan to have this car for a verrrrry long time.
Old Dec 5, 2006 | 11:03 PM
  #34
ЯєŧąяĐ Єl¡m¡иąŧøя ™
They run fine. though. I analyzed it when I seafoamed the SS. were all good! Plus it looked like any other oil change I had ever done. No oil fudge brownie chunks came out or stuck in the bottom of the pan.
Old Dec 5, 2006 | 11:06 PM
  #35
BayAreaSS's Avatar
what oil did you run before the M1 0W40???
I am using M1 5W30 syn.. i wonder what kind of change will happen with the 0W40??
I was using M1 10w30
Old Dec 6, 2006 | 10:58 AM
  #36
what about just like a dino havoline 10-30
Old Dec 6, 2006 | 09:40 PM
  #37
Lythropus's Avatar
I used mobile 1 10w30 for over 45,000 miles after foaming. Changed it every 2500 miles and engine used absolutely no oil, never had any in the intake after about 5 checks over a 40,000 miles period. Using a full 6 quarts it held over 40 lbs at idle and around 65 at WOT. I used 6 quarts because I drove it like it was at the track everyday. Peace.
Edit: Engine had 96,000 when it was wrecked.
Old Dec 6, 2006 | 11:23 PM
  #38
RrCoX22's Avatar
M1 10w-30 syn here for almost 30,000 miles since I've had the car as i just went over the 90k mark and never have had any problems with oil comsumption or chunky gunk ****
Old Dec 9, 2006 | 08:39 AM
  #39
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by RrCoX22
chunky gunk ****
I should ban you for that.... That is gross.
Old Dec 9, 2006 | 09:52 AM
  #40
s1ck s0n's Avatar
i use royal purple 5w30
