just bought a set of long tubes
ahhahahahahha nooooooo GC is bad
mad emy car tick like a fvcking time bomb was waitng for it to blow up
the motor from GM calls for 5W30.. jsut stick with that. i mean it is called for a reason right???
For synthetic Germal Castrol is the best, along with Mobil 1 0w40.
driving it and oil pressure dropped to 0. turned it off.. couldnt figure out what it was, ended up draining out the oil and it came out like cambels chunky soup. had to end up taking off the oil pan and cleaning out the pickup tube and oil pan. the synthetic ended up grabbing everything that was in the lifters and running it though the whole motor.
normal Valvoline 5w30 is all you need
yes, and it ran fine before. if you switch to synthetic after running certian dinos you have the potential for ruined motor. you should pick to run regular or synthetic and then stick with it.
I am using M1 5W30 syn.. i wonder what kind of change will happen with the 0W40??
ahhhhhhh Anthony, i am not the only one lol.. there was another guy that had the same damn problem. he was running M1 5W30, he switched to GC 0W30 he said his car was loud ticking like crazy. he switched back no prolbmes.... See i am not the only one
BTW let me rephrase that. the GM Manual call for 5W30...
GC Problem.. User #2
