How much Shorter is a LS2 Water Pump ??
Old Dec 4, 2006 | 05:22 PM
LM1 Clive's Avatar
Default How much Shorter is a LS2 Water Pump ??
Can you fit a Shorter LS2 Water pump on a LS1 engine ??
Does this cause any problems, and how much shorter are they ???
I'm fitting it in a midengine car, and don't have much room....
Old Dec 5, 2006 | 02:24 AM
RiceKilla's Avatar
https://ls1tech.com/forums/conversions-swaps/542775-picture-my-installed-ls2-water-pump.html
Some good info on the install.
Old Dec 5, 2006 | 04:17 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Do you mean like SBC's and BBC's have long and short water pumps? Which part short/long?
Old Dec 5, 2006 | 02:15 PM
LM1 Clive's Avatar
Great so it will fit... Looks like it only sticks out alittle past the crank pulley...
Cheers Lads...
Old Dec 5, 2006 | 05:22 PM
TheBlurLS1's Avatar
That's what she said...
LS2 pump has same dimensions, just a slight notch in the top for the manifold to clear I believe. The Meziere electric pump design had to be changed to accomodate for this.
