Changing to SD with FAST 90
Old Dec 8, 2006 | 05:32 PM
matts22's Avatar
Default Changing to SD with FAST 90
So I bought a FAST 90 LSX Intake and NW TB from a user on the board, and I'm going to go ahead and bolt it up to the car, even though it won't make a very big difference until I get it ported and get heads/cam.
But, I've been researching what I need to get to make this work. The intake is supposed to come complete as shipped from any dealer.
I can't find any 85mm lids, and it seems that they don't matter much anyway, so I'm just going to reuse my old TSP lid (unless you guys change my mind), remove my MAF, and use a 4.00" 3-ply Black Silicone coupler (hightempsilicone.com) to connect the lid to the TB. I also am ordering two 3.5-4.0" ID (fits from 3.56-4.50") Linear Stainless Clamps to hold it in place.
Is this correct? Is this all I need? Should I consider doing things any other way?
Old Dec 8, 2006 | 05:37 PM
MeentSS02's Avatar
Kleeborp the Moderator™
That's almost exactly what I did to mine, only with the stock LS6 intake and ported throttle body. I just run an SLP air lid with a 3" long, 4" diameter coupler from HTS...that coupler holds on to the lid on one side and on the other to a 4" diameter short length of aluminum pipe, and on the other side of the pipe is a 4" hump hose from HTS that connects the aluminum pipe to my throttle body.
Old Dec 8, 2006 | 05:49 PM
matts22's Avatar
I'm not sure I understand how you have that hooked up exactly, but will that 4" couple be all I need? I mean, will it be long enough and fit both ends? Or will I need one that is a "reducer"?
Old Dec 8, 2006 | 07:49 PM
MeentSS02's Avatar
It'll need to be longer than their 3" length standard size...I'd guess it'd need to be 7-8" long total. You could probably get a longer piece and cut it down to size...
Old Dec 8, 2006 | 08:03 PM
RoastEmSS's Avatar
LG lid and a 4x6 bellow from intakehoses.com
Old Dec 8, 2006 | 08:19 PM
MeentSS02's Avatar
That is also an option...here's mine:
Old Dec 8, 2006 | 11:01 PM
matts22's Avatar
I've been on their website and can't find this...can you send me a link?
Old Dec 9, 2006 | 12:45 AM
RoastEmSS's Avatar
o yea, i forgot they dont have the black one on their website.. u have to call for it. ask for the black 4x6 intake hose with the rings
 Michael S. Palmer
Old Mar 6, 2007 | 08:57 AM
brad8266's Avatar
They now have it on their website.
http://intakehoses.com/Merchant2/mer...ory_Code=CACH5
