!PCV???? worth it?
Old Dec 11, 2006 | 03:54 PM
TheBlurLS1's Avatar
That's what she said...
Originally Posted by BitViper
Im stupid....Why not just run a catch can...
Catch can doesn't catch everything.
Running the fresh air hose is pointles with a breather. The car will actually be sucking crankcase gasses in through the fresh air tub into the manifold under throttle due to a slight vacuum. With it capped on the throttle body, ALL the incoming air is metered.
Plug every hole, and run a breather, just stay on top of your oil changes.
Old Dec 12, 2006 | 03:10 AM
parbreak's Avatar
Originally Posted by 98Camarod
I thought if you run a breather you would have to delete the entire pcv system.
That's what we're talking about: deleting the PCV system.
Old Dec 12, 2006 | 07:23 AM
98Camarod's Avatar
Thats what some people are talking about, some are talking about running a breather and the pcv system with a catch can. It will not work correctly.
Old Dec 12, 2006 | 07:49 AM
98-LS1's Avatar
This may sound dumb but it works, I'm using a Detroit Diesel fuel water separator as a catch can on my Z-28. It came with the mounting bracket, the filter and has a petcock valve to drain the oil out when full. I ran both lines into a T fitting then through the inner fender and up to the filter, which is all hidden so there is no clutter.
Then the outlet line runs next to the radiator and up to the throttle body. I was getting lot's of oil consumption and water condensation back into the intake but after running this set-up the intake is nice and dry. I painted the bracket and filter assembly a nice anodized blue so it looks aftermarket and hides the Detroit lettering.
Old Dec 12, 2006 | 09:55 AM
lsx24's Avatar
This might also be a dumb question but if you run a breather doesn't the inside of your engine bay get all gunked up with oil mist?
Old Dec 12, 2006 | 11:04 AM
98Camarod's Avatar
I would say that it would be minimal. I ran breathers on all my old motors with no problem. The only one that omitted any oil was the one that had 150,000 miles on it. And it was still very little. As long as you clean the breather after each oil change there should not be a problem.
Old Dec 12, 2006 | 12:30 PM
TWISTEDTA's Avatar
Originally Posted by parbreak
Yep, you run a hose from the LS6 valley cover pipe to the intake manifold with the PCV valve still in place. That link shows how to do it.
Here's a pic of my set up with braided lines:
As you can see, you still need to maintain the hose from the throttle body to the passenger side valve cover. That will provide the fresh air.
That looks freaken great! One question, where are the coil packs!?
Old Dec 13, 2006 | 02:33 PM
Luna's Avatar
Thats what I thought, just got a little worried after I see a few people running the fresh air tube since mine has been gone for a while.
As for coating the engine bay in oil mist. I have been running a breather for about 4,000 miles and it only smoked a little bit for the first 1,000 after the breather got a good coating of oil on the inside it stopped. Honestly the PCV delete was one of my favorite mods, the car ran so much better without it, something about having only air fuel and spark in the combustion chamber just makes it run better
Old Dec 21, 2006 | 04:23 PM
TransAminal's Avatar
Originally Posted by FL Junkie
rip it all out, plug the holes, and stick 2 breathers on it. reduces useless engine compartment clutter.
Where did you stick the breather filters?? Did you drill out the valve covers, or stick them on the existing valve cover ports for the PCV system??
Old Dec 26, 2006 | 09:22 PM
NXZ's Avatar
NXZ
I have the LS6 set up and also a breather on the oil fill neck. Should I do away with the Breather and just keep the LS6 set up?
Old Dec 27, 2006 | 09:34 AM
erikthegoalie's Avatar
hey guys as an update here is what I did...
just capped off ANY fitting I saw....all of the ones on the TB, valve covers, etc
Then I added a Metco breather where the oil fill cap goes as ventilation...we will see how it goes
Old Dec 27, 2006 | 09:44 AM
  #32
FL Junkie's Avatar
stick them on the breather tubes on the valve covers and put a hose clamp around it. the passenger side has 2. i put one the fresh air tube, and capped the rear one. on the driver side cut the pcv hose and clamp it to it. cap all the other holes off.
Old Dec 27, 2006 | 10:47 AM
  #33
Luna's Avatar
You don't even have to do that. You could get a Metco breather that screws in right in place of the oil cap, or get a cheaper breather from autozone or something and drill out the existing oil cap (this is obviously cheaper). You COULD run a 3/8" hose from valve cover to valve cover in the back but you don't have to, the engine will equalize pressure internally. Cap off everything else. Sticking breathers into the hose will look really messy and cheap IMO. it will work fine, but won't look great.
Old Dec 27, 2006 | 02:27 PM
  #34
FL Junkie's Avatar
the colorful red and blue ricer filters decorate my engine compartment.
Old Dec 27, 2006 | 03:07 PM
  #35
yeah i just capped off all openings and added a metco breather....thats all you need, the engine will equalize as mentioned...
Old Dec 27, 2006 | 03:24 PM
  #36
Ericbigmac83's Avatar
I may do the Autozone version today. What all do i have to cap off and what size?
Old Dec 27, 2006 | 03:49 PM
  #37
99kamarokid's Avatar
do u have to change the pcv if u put on a ls6 intake??
Old Dec 27, 2006 | 03:55 PM
  #38
FL Junkie's Avatar
the metco breather is like 50 bucks....its cheaper to get the little ones.
Old Dec 27, 2006 | 05:40 PM
  #39
Cool, thats what I did. I left the fresh air tube on there though, I don't think it sucks up oil like the PCV tube does.
I also drilled my oil cap and stuck a breather on top of that. Its a PITA with a strut tower bar, since the bar practically goes right over the oil cap, but I made it work by using a tapered breather filter
Old Dec 27, 2006 | 05:42 PM
  #40
Just get the Autozone breather filters. They fit right over the metal fittings on the valve covers, and then just throw a hose clamp on each one.
Cap off the PCV port on the throttle body and remove the PCV hose, it will no longer be needed.
