LS6 question
Old Dec 16, 2006 | 02:06 PM
aaronbetzner's Avatar
Default LS6 question
I installed an ls6 intake today and when revved it stays around 2 grand and slowly returns to normal idle. It then slightly revs in cycles. Is this the computer relearning? Is it a vacuum leak? Thanks for your help.
Old Dec 16, 2006 | 03:18 PM
Blacker's Avatar
I would assume vacuum leaks. Check all of the hose connection and make sure you did not pinch any vac lines.
Old Dec 16, 2006 | 04:47 PM
It does idle back down to normal though. Would it do that with a vacuum leak?
