vacuum pump.............
Old Dec 20, 2006 | 08:55 AM
C_Williams's Avatar
Originally Posted by 11 Bravo
So what determines when an engine needs one?
Number one reason is to make horsepower and that is acheived because the vacuum pump creates a vacuum in the crankcase to help keep the oil off of the cylinder walls and out of the combustion chambers. This decreases the possibility of detonation caused by oil contamination in the combustion chambers.
On streetcars, a vacuum pump is highly effective and certainly, you make more power. However, there is minor, routine service maintenance that needs be adhered to in order to make these systems “daily driver friendly”.
Since vacuum pumps also reduce drastically the amount of “blow by” many end users use them to stop/reduce excessive oil consumption issues. However, using a pump to control "blow by" is generally not a good choice - addressing the root cause of the oil consumption is the long term cure
Charlie
Old Dec 21, 2006 | 06:58 AM
11 Bravo's Avatar
Oh I know, I just asked more for sarcastic reasons because the other guy didn't really know what he was talking about. BTW, the vaccum pump setup shown in post #1 will work on f bods.
Old Dec 21, 2006 | 11:59 AM
ls1408cp's Avatar
well do one then report back they are not daily driver friendly. We will see who knows what.
