Gutting cats
Old Dec 19, 2006 | 08:58 AM
jeclair's Avatar
Question Gutting cats
How much work is involved in gutting out the cats on a 99 Z28, Do I have to take down the whole stock exhaust, or does the cats un-bolt from the exhaust and worked on ? I'm trying to find a diagram of a exhaust system for the f-body. Thanks for any help
Old Dec 19, 2006 | 09:06 AM
skifast87's Avatar
i just had mine replaced they are welded in on my 02. The Y pipe unbolts. However i dont think the cats do.
Old Dec 19, 2006 | 11:04 AM
cwaldt's Avatar
Its not that hard to gut a cat. All you have to have is a pry bar to reach in there and break the packing up. But if you just gut your cat your going to cause turbulance in that area of your exhaust. To properly do this you need to run a straight pipe through the cat. That was it doesn't create unwanted turbulance and from the outside everything looks stock.
Old Dec 19, 2006 | 11:14 AM
jeclair's Avatar
How hard is it to get the cats out to do that ? Do i need to unweld anything or just un bolt them. Thanks for all the replies
Old Dec 19, 2006 | 11:24 AM
blertawho's Avatar
Originally Posted by cwaldt
you need to run a straight pipe through the cat. That was it doesn't create unwanted turbulance.
have you done this? what size of pipe do you need to run.
Old Dec 19, 2006 | 11:29 AM
cwaldt's Avatar
I did this on My LT-1. You run whatever size pipe the inlet/outlet is on your cat. Basicly your just running your exhaust through there with out any disturbances.
Old Dec 19, 2006 | 12:02 PM
brad8266's Avatar
I did it on my aftermarket cats. I gutted them, stuffed a straight pipe through and welded it shut.
Old Dec 20, 2006 | 12:23 AM
Jordan S.'s Avatar
Get your cats taken off and take them to your local auto recylcer.
Have pipes welded in their place.
You can get about $100 for those cats. thats what the pay around here.
Old Dec 20, 2006 | 11:29 AM
LS69TA's Avatar
If you live in a place that does visual inspections you're screwed if you do that though.
Old Dec 20, 2006 | 01:24 PM
Jordan S.'s Avatar
What are those? I live in Oklahoma
Old Dec 20, 2006 | 01:27 PM
ws6togo's Avatar
If your gonna gut em why not just take them off and run your exhaust without them
Old Dec 20, 2006 | 01:29 PM
brad8266's Avatar
In order to pass a visual.
Old Dec 20, 2006 | 02:24 PM
LS69TA's Avatar
I'm in BFE Texas
Old Dec 20, 2006 | 05:51 PM
robster's Avatar
mine on my 02 just unbolted, no welds
Old Dec 20, 2006 | 06:16 PM
staringback05's Avatar
theres no need to weld anything, you can take them off and completely gut them with a rod....there will be more noise and more smell.....jeclair i see your in jacksonville, if you need some help let me know
Old Dec 20, 2006 | 10:24 PM
Slamed01Ramair's Avatar
I'm pretty sure it will but will gutting the cats set off the check engine light?
Old Dec 21, 2006 | 01:49 AM
Jordan S.'s Avatar
Who cares?
Of course it will.
Old Dec 21, 2006 | 01:51 AM
Starz T/A 17's Avatar
That is why theirs a CPU tune or 02 sims...
Old Dec 21, 2006 | 09:26 AM
8GTOKLR's Avatar
Dont gut your guts unless you run a straight pipe thru them. without a pipe they act as resonators so know you've added 2 resonators to your exhaust and made your flow worse + the smell.
Old Dec 23, 2006 | 01:42 AM
I'm an LS1 newbie so I could be wrong but I don't see how gutting them is going to make the flow worse? Please fill me in?
