anybody make a tool to hold the damper on a C5?
Old Dec 23, 2006 | 10:27 PM
mvvette97's Avatar
Default anybody make a tool to hold the damper on a C5?
Need to get the bolt tight but can't hold the engine. Is there a tool that would clamp on the damper that is made for the C5 vette?
Old Dec 24, 2006 | 06:40 AM
joelvette's Avatar
summit has one about 35 bucks
Old Dec 24, 2006 | 02:02 PM
The1N_only's Avatar
if its a M6 just put it in gear, and if its an auto pull the starter out and wedge a prybar against the flywheel to keep it from turning
Old Dec 24, 2006 | 02:14 PM
TheBlurLS1's Avatar
That's what she said...
Make SURE you disconnect the negative battery terminal before working on the starter though, or your wrench is going to end up welded to the block.
Old Dec 24, 2006 | 02:40 PM
The1N_only's Avatar
ha ha i did forget to mention that huh
