Help! Need torque specs for Header bolts
Old Dec 26, 2006 | 10:02 AM
ryle's Avatar
Default Help! Need torque specs for Header bolts
I'm in the middle of installing my new XS Stainless headers and I kinda forgot to look up the torque specs for the header bolts. Seeing as this is an aluminum block I don't want to be wrong. Anybody wanna lend a hand?
Old Dec 26, 2006 | 10:03 AM
TORCHD 02 TA's Avatar
tighten them til you can not tighten them anymore??
That is what i did with my locking header bolts
Old Dec 26, 2006 | 11:39 AM
jimmypop13's Avatar
TIGHT! It's kinda hard to get a torque wrench to all the bolts & you may need to get under the car for some. Also don't forget to retighten after a week or so. I ended up having to replace a gasket cuz I forgot!
Old Dec 26, 2006 | 12:19 PM
bitterchaos's Avatar
just make them tight but don't over do it.
Old Dec 26, 2006 | 12:21 PM
blacksskid07's Avatar
should I use the stock bolt??
Old Dec 26, 2006 | 12:31 PM
to me, i planned on doing LTs only 1 time, so i did it right and bought the stage 8 locking header bolts.. Yes you can re-use your stockers, but a couple of buddies of mine did that, and after a while they came loose and will have to be retightened!
Totally up to you!
Old Dec 26, 2006 | 12:33 PM
the hell with that i dont need my **** comin loose
Old Dec 26, 2006 | 12:37 PM
werd.. now your thinking. Get the locking header bolts
Old Dec 26, 2006 | 01:45 PM
If you're planning on doing cam and heads, I wouldnt lock the bolts cuz you're just gona have to take them off. I used the stage 8 bolts but not the locks. Tightening the bolts isnt hard.
Old Dec 26, 2006 | 01:51 PM
HavATampa's Avatar
Don't tighten until you can't tighten anymore, you'll strip the head. The correct specs are 11 ft. lbs. first pass and 18 ft. lbs. the second pass starting from the middle and working your way out evenly. Like stated earlier, some you just can't get a torque wrench on, so be careful. Check again in a few days of driving.
Old Dec 26, 2006 | 03:45 PM
I tightened from the outside in starting with the back bolt...and made it pretty tight on the 1st pass. oh well, works out for me...
