pacesetter install write up?
Old Dec 27, 2006 | 12:13 PM
ls1lover346's Avatar
Default pacesetter install write up?
i cannot find that really good pacesetter long tube install write up. does anyone know where that is?
Old Dec 27, 2006 | 12:19 PM
brad8266's Avatar
Damn does anyone bother to read the stickies?? Header install is right in the sticky. Here man, but next time search and check stickies first. Exhaust install has been beaten to the ground here.
https://ls1tech.com/forums/generation-iii-external-engine/520845-mod-guide-induction-exhaust-please-read-before-posting.html
Old Dec 27, 2006 | 09:48 PM
bitterchaos's Avatar
header install instructions are pretty much generic. Remove emissions pipes, tale pff coil packs, remove spark plugs, take out dipstick, take off old manifolds, put in headers. Depending on the brand you may need to cut off the aluminum tab on the block.
Old Dec 27, 2006 | 09:54 PM
brad8266's Avatar
Coil packs do not need to be taken off, although it may be easier on the hands and wrists.
Old Dec 27, 2006 | 09:55 PM
presto_z's Avatar
there is no need to remove coilpacks...
Old Dec 28, 2006 | 08:38 AM
Dr. Jeckel's Avatar
makes it alot easier to get to the header bolts though and it doesn't take that long to remove them.
