Opinions: H or X pipe?
<strong>Verbs, I saw the pic of your exhaust in the other topic, are those the 18" Dynomax bullets? or 12? How's the deepness sound of your system? Thanks for the responses guys</strong><hr></blockquote>
18"ers......and the deepness blows the doors off of most heads/cam cars.....my car sounds like it has a cam when it doesn't.
At low RPM's it sounds like I have 10 liters of displacement.
Chris <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
There are 2 articles that talk about the H & X, and back them up with dyno test. Hot Rod, June 2001 issue, and Hot Rod, Oct. 2000.
By the way, does my setup warrant going with 3" dual piping? I just have mildy ported heads(2.02/1.57), Hotcam and Macs. Thanks again
[ February 08, 2002: Message edited by: PatrickZ28 ]</p>
the gains are due to scavenging. it has nothing to do with flow. the midpipes cause the exhaust to escape faster, and higher exhaust velocity gives you more power.
an H-pipe will outperform an X-pipe down low. expect a much more torquey feel from an H-pipe. for peak dyno numbers, the X-pipe will outperform the H-pipe and likely show a little stronger performance at the track. ask yourself where you'd rather have the power: down low or up top. personally, i'd pick an H-pipe because i want the car to feel stronger down low where i spend 99% of my time since it's my daily driver. running a tenth faster is meaningless to me if the car has less bite around town.
an H-pipe will also produce a lower rumble, so if you want deep, an X-pipe is not the way to go. i'm a firm believer that a track car needs an X-pipe and a daily driver/weekend car that spends almost all its time on the street needs an H-pipe. plus, i think H-pipe cars sound A LOT better.
EDIT - well i feel like a dumbass...a 5 year old thread...who keeps resurrecting these old threads? this is the third 4+ year old thread i've posted in in the past week!
rather than delete my post, i'll leave it up for the sake of information. maybe someone on the edge will read it and gain something from it, the gains are due to scavenging. it has nothing to do with flow. the midpipes cause the exhaust to escape faster, and higher exhaust velocity gives you more power.
best of luck.
