PVC Catch can?? Do you recommend them??
Old Jan 4, 2007 | 04:05 PM
sabersaw30's Avatar
Originally Posted by =ZoomZ=
The problem with the Metco breather that replaces the oil cap is , the rocker arm you see when you remove the oil cap will throw oil up and out of the breather at high rpms .
I have heard of ppl welding a plate on the under side of the valve cover to stop the splash effect caused by the rocker arm .
Then the oil cap breather would work just fine .
A breather can works better only because it will capture most of the oil carried in the vapor , allowing you to drain it later.
Did you just run your pcv line to the catch can and plug up the line going to the intake?That is how I want to run mine.
Old Jan 4, 2007 | 06:11 PM
WS6 Canada's Avatar
What is the part # for the k&N filter??
Thakns
Old Jan 4, 2007 | 09:45 PM
mullenh's Avatar
Originally Posted by PassoutWilly
K, maybe a noob question...but how can I can tell if my intake is taking in oil??
unless you are running a race motor leave it alone
Old Jan 5, 2007 | 08:16 AM
98Camarod's Avatar
If you do not want to have oil in your intake, I would not leave it alone. So why not just fix it? You can do several things. Replace the pcv valve and see that fixes it, install a catch can or seperator, or delete the stock items put one or two breathers on it and cap everything off. One of them can keep oil out of the intake. Oil in the combustion chamber is not a good thing.
Old Jan 5, 2007 | 08:32 AM
=ZoomZ='s Avatar
Yes , its that simple .
Old Jan 5, 2007 | 04:42 PM
sabersaw30's Avatar
I was going to do the same exact thing.Thank you.
Old Jan 6, 2007 | 12:15 PM
jimmypop13's Avatar
just curious, why would you want to plug up the line going to the intake?
Old Jan 6, 2007 | 02:39 PM
=ZoomZ='s Avatar
The intake port is used as a vacum for evacuating the pcv vapors and reburning it .
So , if your using a breather can or breathers you dont need that port , but if your using a simple catch can you will use the vacum port on the intake .
Catch cans and breather cans are used on stock motors as well when the
motor is seeing a lot of high rpms and timing .
They are not just for built race motors .
A motor with 75k miles that sees a lot of high rpms and timing will be better off with a catch/breather can .
Old Jan 6, 2007 | 04:43 PM
mullenh's Avatar
i'll say it again this is not a good idea unless you have a race motor. if you have a pvc problem fix it.
Old Jan 6, 2007 | 07:51 PM
ryle's Avatar
...if you have a pvc problem fix it.
I never knew LS1's had a PVC Problem.
Old Jan 6, 2007 | 08:31 PM
98Camarod's Avatar
I dont think they do, not unless they have a toilet installed
Old Jan 6, 2007 | 10:26 PM
  #32
sabersaw30's Avatar
what is the best way to fix it and I will keep it functioning?I have tried everything that is possible and oil is still going right thru the catch can like it is not there.
Old Jan 7, 2007 | 08:57 AM
  #33
98Camarod's Avatar
Have you replaced the pcv? If you are running a catch can and it still goes through it, I would suggest deleting it and add the breather set up.
Old Jan 7, 2007 | 11:31 AM
  #34
firebirdls1us's Avatar
I tried some of the things you guys have tried and........well only one really mine has the ls-6 valley the ls-1 stock pcv has been changed also to the ls-6.........so I tried just the breather on the left valve cover and left everything else alone.Well I guess you have to plug every hole because mine would'nt idle.Took the breather off and put my oil cap back on and idle was fine.
Old Jan 7, 2007 | 11:35 AM
  #35
mullenh's Avatar
what have you done?
Old Jan 7, 2007 | 12:11 PM
  #36
speed_demon24's Avatar
I think he's saying that because the PCV system is there to help keep the oil clean and suck out the moisture/vapors that will contaminate the oil if you just put a breather on the car. If you run a breather and delete the PCV system you should run a vacume pump....
Old Jan 7, 2007 | 01:04 PM
  #37
CHRIZ28's Avatar
Anybody tried the Summit breather catch can? Part number SUM-G1504? Looks alright. Just run a line from the PCV valve to this can and cap the intake port and call it a day. Price is $27 and it holds a quart. Might be better for the cars that are getting too much oil and filling up the Husky's. Dunno, my car's not together yet, but would like to come to a conclusion on this never ending PCV crisis before it goes in.
Chris
Old Jan 7, 2007 | 07:02 PM
  #38
=ZoomZ='s Avatar
Its a big *** can , make sure you have room for it .
Old Jan 7, 2007 | 07:18 PM
  #39
sabersaw30's Avatar
what have you done?
My pcv is still the stock settup with a catch can.I am using the truck pcv valve with the small orrifice hole and catch can and still getting oil in the intake.Alot less oil with the different pcv valve than the stock pcv valve.
Old Jan 7, 2007 | 07:51 PM
  #40
CHRIZ28's Avatar
I'm sure I've got room for it. (deleted A/C, heat, P/S, solid mounts, relocated battery, ABS block, huge coolant tank.) But you're right, might look goofy if it's great big. Just thought it would be alittle easier than some of the others. Is there a power difference between any of them, (vacuum or atmospheric) maybe one allows the rings to seal better? Might be worth looking into. Thanks.
Chris
