PVC Catch can?? Do you recommend them??
Old Jan 2, 2007 | 06:13 AM
WS6 Canada's Avatar
Default PVC Catch can?? Do you recommend them??
Does anybody have the RPM or any other brand of the PVC oil catch can??
Is this a nessesary add on?? I am running about 550rwhp with Nos.
Here is a pic:
http://www.ws6project.com/user_stor/...0b7884bb94b9f1
Please give me your thoughts??
Old Jan 2, 2007 | 06:55 AM
Element's Avatar
They're useful to keep excess oil out of your intake. Some people have more success with them than others, but they're generally a good addition.
Old Jan 2, 2007 | 07:52 AM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
put one on there ls1's consume lots of oil thru the intake
Old Jan 2, 2007 | 09:29 AM
INMY01TA's Avatar
I like mine. Keeps my intake dry.
Old Jan 2, 2007 | 10:50 AM
cowboysfan's Avatar
at that price I'll be getting one soon, very soon! Oh! I do recommend it.
fuerzaws6
Old Jan 2, 2007 | 12:03 PM
black01_WS6's Avatar
I have one and my intake is now bone dry, and the smoke from the rear is completly gone.
Old Jan 2, 2007 | 01:05 PM
Runn's Avatar
I like my AMW
Old Jan 2, 2007 | 01:52 PM
SmaknaSS's Avatar
I liked my AMW but it still was not enough to stop oil from coming in through the intake.The catchcan would stop the oil but not the oil mist that would totaly coat the inside of my intake. I even mounted the catch can in the front of my car to try and cool the oil mist charge.I tried aluminum line PCV line's and all,..Still did not work. I finally ditched the whole PCV system all together and use breathers and now my intake is finally clean.
Old Jan 2, 2007 | 02:18 PM
98Camarod's Avatar
Same here, I got rid of that junk pcv system and threw a breather on there. No problem thus far.
Old Jan 2, 2007 | 04:45 PM
WS6 Canada's Avatar
What kind of breathers are you guys talking about??? a pic would be a helpful(installed)
Thanks!!!!!!!!
Old Jan 2, 2007 | 07:57 PM
SmaknaSS's Avatar
http://i117.photobucket.com/albums/o...knaSS/pic1.jpg
http://i117.photobucket.com/albums/o...knaSS/pic9.jpg
This is an Auto zone breather from the ricer section.
Old Jan 2, 2007 | 08:11 PM
PassoutWilly's Avatar
K, maybe a noob question...but how can I can tell if my intake is taking in oil??
Old Jan 2, 2007 | 08:36 PM
you can take off your lid and open up your Throttle Body up a bit- not have to take off- and take a long cotton swab and see if you can get any oil- black residue.
With oil in the intake it will mess with your tune a bit lower your power a bit.
Old Jan 2, 2007 | 09:35 PM
98Camarod's Avatar
Thunder racing has the metco breathers. I got mine from a user for a good price.
Old Jan 2, 2007 | 10:34 PM
WS6 Canada's Avatar
if i go to the Metco breather do i have to take off the pvc system???
Old Jan 3, 2007 | 09:11 AM
98Camarod's Avatar
Yes, and just cap all the places where the pcv system was leading to. One breather should be fine as long as there is not excessive hp being made. If so then run a breather on the driver side also.
Old Jan 3, 2007 | 09:58 AM
RobbieTransAm's Avatar
What does the Metco breather do over the catchcan?
Old Jan 3, 2007 | 07:19 PM
=ZoomZ='s Avatar
The problem with the Metco breather that replaces the oil cap is , the rocker arm you see when you remove the oil cap will throw oil up and out of the breather at high rpms .
I have heard of ppl welding a plate on the under side of the valve cover to stop the splash effect caused by the rocker arm .
Then the oil cap breather would work just fine .
A breather can works better only because it will capture most of the oil carried in the vapor , allowing you to drain it later.
Old Jan 3, 2007 | 09:59 PM
WS6 Canada's Avatar
Did you modify that catch can to fit the K&N filter?? and if so why did you do it and what are the parts used (part #'s) please, i am very interested in that set up
thanks.
Old Jan 3, 2007 | 10:34 PM
=ZoomZ='s Avatar
Its a new top with a breather and insert that locks it in place .
