POLY MOTOR MOUNTS- hardest install EVER..... HELP!
Thanks to all those who helped!!!
SOrry if I was an *** to anyone...
My advice: 1) get one side in, like the passenger side, and get someone else to help you. I couldnt have done it if it werent for the pair of eyes on the other side of the pedestal saying "okay its almost lined up here, how bout your side?"
2) grind that bolt down to a point!!!!! it will help you a hell of a lot.
3) work at it with some one looking at each side, and as soon as one of the holes lines up take the freshly ground bolt and try to get it started. From there i had a HAMMER and about 3 extensions on the head of the bolt. I got my dad to help move the jack while i beat on the bolt....oh and this bolt went in BACKWARDS, as in the nut is on the front of the mount. With some jack movement (pulling+pushing left right, lowering raising) it will eventually ram home.
Did it all with the headers and the starter still on the car!
heres the deal...,my dad (my best buddy when it comes to helping with the car) has been there with me eyeballing these *******....it seems like when i took both mounts off..that was my mistake, like the engine and tranny is just slightly twsited and now it does not want to line up...
i thought about just putting the bolt in from the back...i basically tried everything except filing the tip of the bolt to a point and driving her home..i dont want to screw up the threads ya know...its not really a matter of up and down movement...it seems like when I have one bolt in, the other mount is slightly off to the right...like the whole engine needs to be moved horizontally...which, by the law of physics cannot occur..soo
like I said, my mechanic is installing the clutch/tranny anyway...I am going to see if he can do it which I am sure he will, he has a lot more hands and resources..and oh yeah PATIENCE....id rather drop the fuel tank to change a pump while it was fuel 5 times than do this again...what a major PITA....hopefully it is all worth it..
Thanks brothas
I dont get why youre so pissy about some old thread about running rich after headers, it isnt something to get pissed about, just a disagreement of the facts.
Try listening to other people instead of getting pissed when people try to help you understand things, maybe then things will be a bit easier for ya. I dont sit here and talk out my *** just to **** people off, I try to help out with **** that I have experience with, not **** that I just hear from people.
Try that out and see how it goes.
