POLY MOTOR MOUNTS- hardest install EVER..... HELP!
Old Jan 3, 2007 | 11:45 AM
brad8266's Avatar
If you loosen up those clamshell bolts be sure to have the engine supported with the jack and piece of wood so you dont put weight on the loose clamshell bolts and bend them. Just keep it supported and move the motor around.
Old Jan 3, 2007 | 12:16 PM
KurtRardin's Avatar
Veteran: Marine Corps
If it makes you feel any better i thought that when i did mine i stripped out a bolt hole in the block! The factory bolt (drivers side front top) was singing to me when i tried to put it back in. Every time id pull it out there would be a fresh bit of aluminum on it... So, i just went and bought a grade 8 bolt from advance and in it went, no hesitation...and no pesky stud sticking off of it. So, at least you didnt scream because you thought you stripped out a bolt in that God awfull place!
Old Jan 3, 2007 | 12:23 PM
erikthegoalie's Avatar
what did you do then with that small heat shield that covers the mounts and protects from header heat?
good thinking...did you apply any loctite to the bolts?
Erik
Old Jan 3, 2007 | 12:24 PM
KurtRardin's Avatar
chucked it. I've never heard anyone talk about puting them back on, so i just left it off
Old Jan 3, 2007 | 12:26 PM
brad8266's Avatar
Erik
trash it
Old Jan 3, 2007 | 12:37 PM
good deal good deal, one less POS in the bay hahah
hey guys I really appreciate the help...i am going to go home and tackel this..see if I can get it...im SO dam close...
Old Jan 3, 2007 | 03:34 PM
outkast6991's Avatar
did you drop the tranny crossmember?this helped me trying to line up the motor side to side when i did my solids.just a thought
Old Jan 3, 2007 | 04:30 PM
welli figured that would help..but i didnt try it...i figured when the mechanic throw my new t56 in and all they can do it easily...i am going to try it again though...
thanks
Old Jan 3, 2007 | 05:23 PM
Firehawk441's Avatar
Like Brad8266 said, loosen the bolts that hold the pedestals to the K-member.This is the ONLY way I've ever been able to get the engine mount bolt in. Then tighten everything back up. Good Luck!
Old Jan 3, 2007 | 05:53 PM
jimbo98z's Avatar
Originally Posted by KurtRardin
Its a rough deal for sure. Thats why people say its one of the hardest thing to do to an ls1. ...
2) grind that bolt down to a point!!!!! it will help you a hell of a lot.
+1
Old Jan 3, 2007 | 06:14 PM
brad8266's Avatar
Well actually I said loosen the clamshell to engine block bolts, but you can loosen the pedestal to k-member bolts too and it will help.
