Motor reinstall
Old Jan 3, 2007 | 05:15 PM
Mike2000Z28's Avatar
Default Motor reinstall
Is there any benefit in reinstalling the shortblock rather then with the the heads on to get the bell housing on easier? Or just reinstall as taken out.
Old Jan 3, 2007 | 11:18 PM
BirdmanLS1's Avatar
Might want to post this in the internal engine section.
Old Jan 4, 2007 | 12:04 AM
Speed Density's Avatar
hashtagBMW
Well if you didnt repost...
I pulled my LT1 as a longblock the first time. It was a pain.
The 2nd time I took the Heads intake off and then pulled it in almost an hour.
Tony.
Old Jan 4, 2007 | 08:09 AM
cwaldt's Avatar
Install everything thru the bottom. Long Block and all your accessaries as well. Its the easiest and best way to change a motor.
Old Jan 4, 2007 | 04:51 PM
I just wanted to know if anyone had more luck doing it just as a shortblock or if installing the heads afterward was a problem to get the rear bolts tightened. Thanks guys.
Old Jan 4, 2007 | 06:21 PM
slow trap's Avatar
i would put it back in with the heads on.the bellhousing bolts isn't that hard to get to but torqueing head bolts isn't fun while the motor is in the car,especially if they are the stock head bolts and you are trying the degree method.
