PCV Catch Can Placement
Old Jan 4, 2007 | 03:21 PM
382WS6's Avatar
Default PCV Catch Can Placement
Does anybody have their catch can located somewhere OTHER than on the front of the passenger-side head? I'm trying to install my can but I still have my EGR system and it is bolted right where I want to put the can and I don't know where else I can mount it. Any ideas/pics would be greatly appreciated. I'm not trying to ditch the EGR system either since I'm in SoCal and the smog ****'s are pretty harsh. Thanks.
Old Jan 4, 2007 | 04:28 PM
01 Red WS6's Avatar
I've seen a few people put it by the battery. Its hidden but you have the lines running to it.
Old Jan 5, 2007 | 09:32 AM
SSpeedracer's Avatar
I mounted an AMW catchcan to the passenger side fog light bracket. The PCV feed and return lines snake through an oval hole just in front of the battery and over to the intake. You need to temporarily remove the battery to run the hose. I used a 3 or 4 inch hose clamp and about six feet of hose.
The fog lights were recently removed and I can drain the can by reaching into the fog light opening and twist the **** valve. Before, when it used to have fog lights, it was simply a matter of removing the two bolts holding the lower splash guard to access the catch can. Simple, nobody sees it, and the cold air helps coelesce the mist.
Old Jan 5, 2007 | 09:59 AM
thunderdan74's Avatar
I put mine next to the fuse boxes and ran a drain line with a valve at the end of it. It comes out just behind the air dam. I dont even have to pop the hood to drain it.
Old Jan 5, 2007 | 07:13 PM
DaddySS's Avatar
LF radiator support just to the left of the radiator.
Old Jan 6, 2007 | 03:22 AM
Dustin 98TA's Avatar
I made my own catch can and put it between the brake booster and the fender. Im running a Procharger setup and have it routed to the inlet hat. Ill take a pic today and post it up.
