TB bypass
Old Jan 9, 2007 | 02:09 PM
brad8266's Avatar
Originally Posted by Justin00SS
What about deleteing the MAF?
Feel a difference there because it flows SOOOO much more without the maf.
Old Jan 9, 2007 | 10:33 PM
JohnnyC's Avatar
I used some heat transfer equations a while back and proved that heating the TB does not significantly raise the temperature of the air as it passes through it. Heating the TB does help prevent TB iceing caused by the venturi effect at extreme cold temps. It is one of those mods that make the TB easier to get off and may provide a slight HP gain due to a small reduction in under-hood temps. Reading this thread will restate everything I just said, except in much more painful detail:
https://ls1tech.com/forums/showthrea...ight=tb+bypass
Old Jan 9, 2007 | 10:39 PM
dpw41285's Avatar
cop car do you daily drive in this weather? any problems with this mod
Old Jan 9, 2007 | 10:41 PM
ULTIMATEORANGESS's Avatar
itll make your eng. compartment look a little cleaner anyway.
Old Jan 9, 2007 | 10:53 PM
bigman's Avatar
i wish i had your butt dyno. Because if you felt that tb bypass, then headers will feel like a turbo.
Old Jan 10, 2007 | 02:02 AM
98goldz28's Avatar
Who is butt dyno?
If your talking about me I do have headers.
Old Jan 10, 2007 | 02:29 AM
bayer-z28's Avatar
^^A butt dyno is what you feel when you accelerate. You will feel a little more after a good mod. Seat Of The Pants = SOTP dyno, you feel pushed back into the seat more.
GMHTP did a thing on free mods in an article. THe TB Bypass was one that made the best gain.
Old Jan 10, 2007 | 02:47 AM
98goldz28's Avatar
Thanks for clarifying that. There's alot of new terminolgy that I am not use to here...lol even when I use the cheat sheet.
Old Jan 11, 2007 | 01:41 AM
Cop Car's Avatar
i havent driven the car hardly at all with this mod. we will see how it plays out after i tune my car
Old Jan 11, 2007 | 02:21 AM
bayer-z28's Avatar
I think the TB P+P give more of a felt effect then the TB BP. My throttle got a LOT more sensitive when I got my TB in.
Old Jan 11, 2007 | 09:44 PM
dpw41285's Avatar
gotcha
Old Jan 11, 2007 | 10:38 PM
  #32
cabech984's Avatar
fugettaboudit, everybit counts right?? Id do it if I wasnt a lazy %&*#!!
Old Jan 11, 2007 | 11:54 PM
  #33
jimmypop13's Avatar
i didnt notice a difference with the TB bypass but i wasn't expecting to either. I did feel it when I added a lid though
Old Jan 12, 2007 | 02:53 PM
  #34
3.4camaro's Avatar
i deffinately felt a new airlid, cuz it started giving me wheel hop.
Old Jan 12, 2007 | 02:55 PM
  #35
RrCoX22's Avatar
you'll get 10rwhp yo!
Old Jan 12, 2007 | 05:17 PM
  #36
presto_z's Avatar
ur but dyno needs to be re-calibrated if u felt the TB bypass..
Old Jan 13, 2007 | 06:54 AM
  #37
Justin00SS's Avatar
Maybe all of his coolant dripped out.
Thats good for what? ~3lbs........maybe its faster because of weight reduction.........
Old Jan 13, 2007 | 08:45 AM
  #38
BigDaddyBry's Avatar
How cold does it get where you are in Oregon? Depending on how cold, you may want that coolant running through.
Old Jan 13, 2007 | 09:49 AM
  #39
JL8Jeff's Avatar
That link was for an LT1 TB bypass and that does make a difference. The LS1 TB doesn't really have coolant going through it, it just contacts the bottom of the TB to help warm it slightly. The bypass on the LS1 won't do much at all. I did it though when I swapped out my TB for a ported one. No cost involved if you have some old fuel lines sitting around and it makes it easier to remove the TB in the future for cleaning or whatever.
Old Jan 13, 2007 | 09:52 AM
  #40
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Every little bit definitely helps. You are correct in that assumption. It did something, but nothing you are going to feel.
