Some stuff i did while changing cam
Old Jan 11, 2007 | 10:30 AM
TransSlam's Avatar
Default Some stuff i did while changing cam
I am in the middle of my TR230 cam swap and was not in any kind of hurry so i messed around with a few things. I installed a set of Pacesetters, they were black painted so i put them in my glass beader and painted them with high heat silver. Then i took my coil packs and made so Fo-msd's-I tried just using krylon fusion plastic paint with no primer and it does not work. It look like crap if you try this. I sanded them with 400 and sprayed them with krylon sandable primer, sanded the primer with 400 then painted them with the red fusion paint. After the red dryed I used some high gloss Krylon clear coat. Next I bead blasted the valve covers, coil brackets and throttle body. Painted them with high heat gloss black engine paint and after they dryed I cleared them with the same brand high heat gloss clear coat.(worked really well) I have the front timing cover and alt. bracket sitting in the blaster that will also be painted the same way.
If anyone hates it, I dont care. Its my car and i could have painted everything P*#%y pink if I wanted to.-(they were all out so i used black)
Attached Thumbnails Some stuff i did while changing cam-f70416e9-6619-419d-bdf7-80689a60f4c0.jpg   Some stuff i did while changing cam-3b424b79-1c63-4715-92e9-315b6a3d4387.jpg   Some stuff i did while changing cam-06e30067-3eae-457c-94f6-6b2b79df6577.jpg   Some stuff i did while changing cam-ded24482-50ea-4f6c-845c-8c96c112f748.jpg   Some stuff i did while changing cam-9bb29c02-6e68-4efa-bb01-31c0bc3030b4.jpg
Old Jan 11, 2007 | 11:08 AM
HAMRHEAD's Avatar
Nice work
Old Jan 11, 2007 | 11:27 AM
98Camarod's Avatar
Looks good to me.
Old Jan 11, 2007 | 11:44 AM
BIG_MIKE2005's Avatar
Looks good. I was wonderin about the red fusion paint also. I'm gonna do the same with my packs except the valvecovers will be blue(look anodized) & the coil brackets will be silver or polished.
Old Jan 11, 2007 | 12:08 PM
TransSlam's Avatar
Yeah get the krylon brand grey primer-works great. without primer the black plastic bleeds threw the paint to much. Then get the krylon clear coat.
Old Jan 11, 2007 | 12:23 PM
bigfoot2thefloor's Avatar
Old Jan 11, 2007 | 12:28 PM
Thankx for the hint.
Old Jan 11, 2007 | 12:31 PM
erikthegoalie's Avatar
amazing...i will do my coil packs also, I was wondering how others did it..now I know..
Old Jan 11, 2007 | 12:33 PM
Ericbigmac83's Avatar
Looks good, im gonna do mine if i ever get any free time
Old Jan 11, 2007 | 12:40 PM
cowboysfan's Avatar
will it hold up to the engine bat heat? how long? looks good. just wondering how long paint will last.
fuerzaws6
Old Jan 11, 2007 | 12:55 PM
TransSlam's Avatar
i did the valve covers and coil brackets in 1200 degree high heat paint and clear coat. The coil packs are fusion paint. I have not finshed my cam swap yet so i will post back up if i have any paint issues with the coils. Should be alright the coils do not get that hot anyway.
Old Jan 11, 2007 | 01:49 PM
Yea, I'm thinking about using the VHT red I used on my brake calipers for mine now. Still goin with the primer & high temp clear though. I like the brightness of the VHT red.
Old Jan 11, 2007 | 03:28 PM
bjamick's Avatar
Im sorry what are we talking bout all i seen was that avatar
Old Jan 11, 2007 | 04:01 PM
Tainted's Avatar
BAD BAD BOY!!! get those headers coated not just painted!
Old Jan 11, 2007 | 04:33 PM
Red99TA's Avatar
I'm with you man, all I can see is big *** tats about to bust out!
Old Jan 11, 2007 | 04:56 PM
TransSlam's Avatar
I installed and bought headers the same time i bought all my cam stuff, so getting coated headers was not in my budget. At least i bead blasted them and coated them with high heat. I went ahead and settled for non-coated pacesetters that fit correctly vs: ss ebay headers that has that stupid bent angle on one side and no y-pipes that fit.
Old Jan 11, 2007 | 05:08 PM
TheBlurLS1's Avatar
That's what she said...
Looks nice!
Did you know that lots of paint places can make special paint matched spraypaints? Bring them a color and they send it off. It comes back in aerosol cans. If someone started making it, they could make a killing on here selling it in the different F-body colors (SOM, NBM, HO, etc.)
Old Jan 11, 2007 | 05:17 PM
Tootall's Avatar
Where did you get the paint from? Online, local store?
Old Jan 11, 2007 | 05:26 PM
Tainted's Avatar
actually the jet hot y pipe fits like a glove and went in awesome so that was kind of a **** poor attack on the ebay headers.
Anywho You should have seriously waited and got the ceramic coating I dont think I need to tell you why
Old Jan 11, 2007 | 08:57 PM
dude avatar needs to become sig pic...NOW
