solid motor mounts
Old Jan 13, 2007 | 11:27 PM
99kamarokid's Avatar
Default solid motor mounts
what is the purpose for the solid motor mounts?? and does it shake the car hardcore?
Old Jan 14, 2007 | 07:55 AM
Red99TA's Avatar
these are more rigid than the poly mounts that most people install. Basically you're getting rid of any "give" that the stock rubber mounts have. You will get a little more vibration especially through the shifter. I just installed a poly on my driver's side to stop the motor from twisting so much under acceleration. My ORY is pretty close to the underside of the car and each time I went WOT it would bang. The poly mount stopped the banging which is why most people install them. That and it just gives a more solid feel to the car.
Old Jan 14, 2007 | 05:32 PM
1CAMWNDR's Avatar
I have Spohn solid motor mounts in my car. There is very little vibration; although I have a stock cam for the time being...... The shifter does have a slight vibration, but it does not walk 2" to the passenger side when the motor revs. It no longer moves at all. That is a good trade off as far as I am concerned. When starting the car there is something of a thunk as the starter engages the flywheel as the motor will not roll over in response to the starter gear's torque.
I love them on my daily driver.
