KOOKS Catted Y
Old Jan 18, 2007 | 10:18 PM
fastss's Avatar
Default KOOKS Catted Y
I orderd my kooks 1 3/4 long tubes with a kooks catted Y ( im in CA so i dont want to risk it with an ORY) My question is does anyone else have this settup, and if so have you had a problem with your Y-pipe hitting or rubbing under the car in any place?
Old Jan 18, 2007 | 10:31 PM
fastmatt98's Avatar
I have it and have no rubbing issues at all
Old Jan 18, 2007 | 11:00 PM
SweeTbone's Avatar
No rubbing or bumping at all. Still on stock motor mounts also.
Old Jan 18, 2007 | 11:33 PM
TheBlurLS1's Avatar
That's what she said...
My friend has that setup with GMMG and it all fits/works perfect.
You're still going to fail California inspection simply because you have LT's. Cats or not.
Old Jan 19, 2007 | 12:36 PM
Arctic2002ss's Avatar
Mine hits sometimes. New motor and tranny mounts helped a lot but still happens occasionally.
Old Jan 19, 2007 | 10:37 PM
fastss's Avatar
I have a smogshop that will pass me so thats not a problem. the reason im getting a catted Y is because every time ive been pulled over and also been pulled over in my friends cars, the cops always look to see if you have cats, a couple of cops have told me that they can overlook having longtubes, but having not cats is just asking for it.
Old Jan 20, 2007 | 11:29 AM
noah89's Avatar
Check pics in sig. No probs in 3 years.
Old Jan 21, 2007 | 10:06 AM
99zman's Avatar
0 issues here with kooks long tubes and catted-y
 Michael S. Palmer
Old Jan 21, 2007 | 10:26 AM
99HUGGRSS's Avatar
unfortunately, i have the same setup as you,but mine is stepped to 1 7/8.it hits all the time. drives me nuts. also have the same setup with my 2000 z-28(1 3/4)headers,with no problem at all. not sure if the header is hitting the k-member or the y-pipe is hitting the floor board under my ***! had a real bitch of a time getting the driver side header in.had to jack the engine up about 2-3 inches, remove the motor mount to get the header in.
Old Jan 21, 2007 | 10:52 AM
TheBlurLS1's Avatar
If you have a stock k-member with the 1-7/8 headers, I can almost promise they are hitting on the passenger side. Here's how I had to grind mine to get my 1-7/8 Kooks to fit....
http://i38.photobucket.com/albums/e1...t/IMG_1702.jpg
Old Jan 21, 2007 | 10:56 AM
ErikElvis's Avatar
Mine hasnt banged yet. Close to touchin in some areas though. I think it tucks real nice
Old Jan 21, 2007 | 03:35 PM
fastss's Avatar
Thanks alot guys for the info!!!
Old Jan 21, 2007 | 03:46 PM
ErikElvis's Avatar
OK I did get some mild banging turning and gunnin it. I think its hitting my SLP SFC's. STraight line no prob though
Old Jan 21, 2007 | 04:13 PM
gman's Avatar
I switched to 1 7/8" kooks from 1 3/4" kooks about a month and a half ago and had no fitment issues or hitting at all with the stock k-member. While installing them the driver side header needed some persausion to be pushed up into place, but the passenger side slid right in.
